Heating & Cooling Logo
Posted on May 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set the day with the Honeywell vision pro TH800 series thermostat screen
Anonymous
Level 3:
  • Honeywell Master 43,501 Answers
  • Posted on May 11, 2011
Anonymous
Honeywell Master
Level 3:
Answers
43501
Questions
0
Helped
10844069
Points
101584
Press the "system" button
Then press and hold the center blank button till the advanced functions menu comes up...
Then set the year, month, and date and the day will be correct
Check out pages 21 and 22 of this manual...
http://www.honeywell-thermostat.com/manuals/th8321u1006manual.pdf
heatman101
Visionpro problems
Remove the batteries and remove the R or RED wire from the thermostat's sub base R/ RED terminal for 1 hour, if this does not work, replace it.
1-800-honeywell
www.honeywell.com
How to unlock screen
Change battery located on back of thermostat??
Go to google
Search for your model number 1234XX .pdf
Add .pdf in search parameter.
Honeywell posts most their thermostat manuals.
Open pdf file, and then Use Ctrl+F for search feature
Word-Search manual
To find model number on thermostat, remove from wall.
Model number appears on back.
Don't forget to replace battery while you have back exposed.
Dead battery can also cause lockout and malfunction
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I have a honeywell III chronotherm thermostat /It won't turn on the heat or the air conditioning when turned to those settings, but it sometimes will when turned to "auto". The batteries seem fine, no...
it sounds like it is time to repalce the stat, auto is set to allow the fan to run only when the heat or a/c is on, the switch for heat and cool will select either, and the temperature lever should allow contact for the bulbs to bring on the desired component. there are no replaceable parts on a thermostat, or I would try to walk you through replaceing them. good luck.. I prefer the honeywell vision pro or the white rodgers 9500 series stats
3helpful
My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
Upstairs honeywell thermostat went out on 3/7 [no display]
FIRE THIS GUY!!!!
You have two systems.
These two systems should be wired totally independent of one another. I have the Pro series t/stat in my house. I love it.... I am a retired contractor I get stuff at cost. I paid about $130 for that t/stat. I understand he is in business to make money. But he should be fair enough that in the future you would want to call him back, Or even give him a nice referral. Alol this guy wants is your money. If the first guy admitted thatbhe did not have the expertice. He shouldn't be paid the experts price.
Call your city or county building inspectors office. Tell them that you would like a list of 4 or 5 reputable heating contractors in your area.
$275 should be fair for the nice t/stat and a fused transformer. Although a cheap t/stat would be fine.
Plus 75 bucks to pull upthe driveway. 60 -90 bucks labor to staighten things out. You should not have to pay for the romantic weekend away for the contractor and his wife.
GOOD LUCK!
5helpful
Locked screen on a vision pro 8000
select system, hold down the two boxes immediatly to the left and right of the center box for 3-5 seconds
Top Honeywell Heating & Cooling Experts
Paul Carew
john h
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
