It could just be lint or flashing inside the tubing which connects to the pressure switch. Remove the tube and blow it out and make sure ain't no holes in it. Remove the top to access the analog pressure switch item 20.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Hello & Welcome to FixYa
F35 error means that there is some sort of issue
with the steamer electronic board and analog pressure sensor has gone bad.
Check that the hose is firmly attached with the washer and is not blocked. You
can also check the water level pressure switch operation. Please get back to me
if you have any other questions.
Kevin
