this is sme serious sh*t im just kidding download sonyericsson update service run the program and it should guide u how to update your phone firmware and see if your battery i ok like change into another 1 if u have at home or ask friend tolend u his and see if it still occurs problems with the phone
Please contact your service provider for the MESSAGE SENDER NUMBER which must be put into the phone in the phone settings- messages- message settings.
Once this is done the phone must be able to accept after choosing the message sender number as the default number.
It's quite easy and done in about 5 minutes! You just have to remove the aluminium-panel on the backside of the display-slider (when slider is opened and you look at the mobile from backside)! This part is fixed with adhesive and so you can remove it carefully by lifting an edge of it with a thin slotted screwdriver (for instance) and then insert something like a credit card in this lifted edge an remove the whole panel with it. After this you'll see two little screws you also have to remove before you can take off the front-cover of your mobile. Now there is only one screw left to remove. It's on the front-side beneath the display. When you're done removing all this screws, you have to be very careful. The old display can be removed by disconnecting it's flex-cable from the circuit board (this little board you just removed the mounting screw from, the cable-connector is on the backside of it).
Now you only have to insert the new display, connect it to the circuit board an do all steps in reverse to assemble it again.
