Question edited for clarity plus 'want' to 'won't'.
Question moved from MISC to a better category.
Try a reset, or return it for warranty repair.
If you have a SkyCaddie Watch, SkyCaddie Linx, Aire, or Aire II you can reset these caddies by pressing and holding down all 4 of the corner buttons for about 6 seconds. The screen should fade out and then you can release the buttons.
Are you actually turning the tablet off when you are not using it? (Hold down power button until Power Off box appears on screen)? If not, your tablet is constantly using power even with the screen blanked and will drain the battery. You could have a bad battery that is no longer holding its charge. How long can you run the device off the charger continuously? That length of time might indicate the state of the battery. Check the manual for expected battery life, which for a Linx 7 is usually 4 hours or less.
please go to web page from Hoover and see the videos respectively from your model, etc. http://hoover.com/support/video-instruction-guides/ However this can be a problem:There could be a clog in the hose or the
bag/tank may be full and need to be replaced or emptied. Also, check the
belt to see if it is worn or broken, if it's defective replace it.
You need to go back to pinnacle, follow links on their website for support and or downloads see if there are updates for windows 7. If no, use their contact us link and ask them.
