The DVD gets stuck inside Philips DVP3140 DVD Video player. Eject button opens the DVD door and the tray comes out empty. I can see from the open door that the disk gets stuck inside.
I tried various methods. I tapped the player while ejected the disk, etc. Nothing worked.
What should I do?
There are two ways to open the CD/DVD drive door
if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive
tray next to the Eject button. Push the paper clip gently until the drive tray
pops out, then pull the tray until it is fully out, then you can remove the
CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD
drive is faulty and needs replacing.
your gonna have to open the machine up the there is a whits tab that lifts the disc up to spin you will have to use your fingers to slde it of that make sure its unplugged and then the white thing will realese
LETS SEE , check out first your REMOTE CONTROL , it could be that some buttons are stuck sending signals . this is how your going to check : lay down your remote and using a digital camera , point it to the EYE of the REMOTE , now look at the screen of your digital camera , if you see the EYE of the remote BLINKING !! thats your problem there. hope its works. AJ
1. Make sure that tray is empty and no DVD is in 2. Turn the unit off and the on again 3. Open the tray 4. On the remote, hit 9879 and the region code. For any-region support hit 0. 5. Very important - hit OK on the remote.
I had been closing the door at the DVD slot manually. I found that if I closed the DVD door with the close button, and then opened it with the open button, it no longer got stuck.
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and . Now
press the button at just after that apply a force on niddle .suddenly
you will notice that cd will come outside ,if not try more times and
you will learn to eject the cd when you are unable to do it by pressing
the eject button... ------------------------------------------- Low feed backs hurt my
ratings and I am tring to help you with your problem,so let me know
that the information i given you is helpfull or not.
