There is a problem with the power button on the speaker asnd when i press it, the power turns on for a second but doesnt stay on unless i hold it down. the actual button stays down, but the power doesnt stay on.
Try doing default factory settings. Step 1. Press the "Power" button located on the top center part of your JBL Charge 4 Bluetooth speaker. The speaker will be powered on when the LED backlight under the Power button is lit. Step 2. Hold down the "Bluetooth" and "Volume Up" buttons at the same time for roughly three seconds. The Volume Up button looks like a plus sign. Additionally, it's important to hold down the "Bluetooth" button in the center of the device next to the Power button, as it's easier to hold down. After three seconds, the LED ring around the Power and Bluetooth buttons will briefly light up before the JBL Charge 4 powers down. Step 3. Press the "Power" button again to turn the JBL Charge 4 Bluetooth speaker back on. The Charge 4 will instantly turn on in Discovery mode, with the Bluetooth LED blinking on and off, and the speaker making a pinging sound. This confirms that you've successfully reset your JBL Charge 4 to its default factory settings. You'll need to pair or re-pair any devices you want to play audio through the JBL Charge 4 speakers with the device.
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work: Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears •Release the power button but *continue holding the home button*, for another 30 seconds. Step Thanks
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD. * If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
May need to do this with if off (OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then press power button to turn the monitor on.)
