Hello I am trying to install Windows 2003 server on Dell PE2950 and Serial no DG9QFC1 . However while installing I get following error that no hard drivers found...
It would be helpful if u can assist me in this
It depends on what type of drive you are using. Plus, you may have to specify the array controller drivers if your are using the SAS (Serial Attached SCSI) drives.
If your Dell server cam with the Windows Server 2003 software, you should be able to order a replacement cd. Go to http://www.dell.com/support If the software was not packaged with the server, you will have to buy it at http://www.microsoft.com/sales
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
If the computer is telling you that the hard disk is not found, then either it is not hooked up correctly, is set to "disabled" in the BIOS setup, or the hard drive is bad. Check those things in that order.
First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty.
Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty.
The hard drive needs to bereplaces in the laptop and Windows installed and the laptop's device driversand your programs etc to get a functioning laptop again.
ok you will need to get the windows 2003 drivers for your raid controller and put them on a floppy disk. when you first boot off the cd you will see a prompt to press f6 if you need to install any additional drivers. insert the floppy disk and select which driver you wish to load.
you should be able to see the hard drives now to partition/format.
Seems that Seagate did not release a version of software which could be used on a Windows Server 2003 platform. I checked their web site at the following link & didn't find any software supported on Windows Server 2003: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=freeagent-downloads&vgnextoid=3723b5b59b7d5110VgnVCM100000f5ee0a0aRCRD
Sorry, but I can't help you with this one. Try contacting Seagat for this & see if they have a solution to your problem.
