After a very extensive cross reference session your engine is model number
10H902-0285-E1 (not provided by you so it took a while)
Your engine is covered in this repair manual:
http://www.mymowerparts.com/pdf/Briggs_&_Stratton_Service_and_Repair_Manuals_Spec_Charts/270962%20Single%20Cylinder%20L-Head%20BRIGGS%20&%20STRATTON.pdf
If there is a problem that your having I can help you if you would just elaborate. I could save you lots of time. The 2 most common failures of this engine is on the carburetor. The parts that fail are the diaphragm (Item 394) and the primer bulb (Item 976) of this link:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=10H902-0285-E1&dn=57160004
Carb data is in section 3 of the first link.
Thanks for choosing FixYa,
Kelly.
Governor repair on 445777 0112 E1, 23hp Briggs and Stratton, Garden Tractor
I need help. Whoever worked on my mower before. Didn't put the 2 springs on throttle in the right positions. I thought I had taken care of it last year. I gave it a tune up today started mowing. After a couple passes it revved down to basically an idle. I can't find a diagram so I can put them back in the correct position
