SOURCE: No sound from my Logitech headset when on SKYPE
Maybe you need to select which Audio device you are using within Skype. It the Settings under Audio you should be able to select the default audio device that Skype talks to. If you set it to the USB headset, it might work properly.
SOURCE: Headset & speaker both are playing at same time
Most probably headphone socket in the laptop is dirty. Spray some WD 40 or replace it.
