Question about HP Pavilion dv6000z Notebook
Hp pavilion dv6000 Blank SCREEN
Hi my screen is out leaving me with zero function the only differences i can see without the screen is that the wireless signal light in front and also my volume and cd port lights are red..in addition to this the cd port will not open any info or reconmendations would be very helpful im lost
  • 6 more comments
  • Anonymous Aug 14, 2008
    same thing happened to me today, know how to fix it yet?
  • Anonymous Jan 15, 2009
    never worked for me..I tried everything suggested..I guess I got the **** one with the dysfunctional motherboard
    never worked for me..I tried everything suggested..I guess I got the **** one with the disfunctional motherboard
  • rattboy501 Mar 10, 2009
    Windows Vista boots, log-in screen, welcome screen...then BLACK screen. Although I still have a cursor, and ctrl+alt+dlt allows me to bring up task-manager.
    Oddly enough, I can use the help menu in task manager to browse the internet (which is how I'm asking this question)
    Any suggestions?
  • rowlandbw Mar 29, 2009
    I had the some problem with HP pavilion dv5-1180eh , the solution, power off, remove battery, etc. worked on dv5-1180eh too.
    http://h10025.www1.hp.com/ewfrf/wc/docum...
  • r_lee3 Apr 08, 2009
    Pc turns on. All lights are on but no screen
  • alvinheu Apr 28, 2009
    i have the exact problem with the blank screen
    ive tried the holding the popwer button for 30 to 60 sec and still nothing
    the first time i tried it when it started up the hp sign came out very bright then dim down to where you can't even see
    anyother solution to this problem
  • Steve Si
    Steve Si May 11, 2010
    Do you see any text or graphics at all on the screen when you switch on PC?
OK, if you had the problem I had, I have a solution
I had a problem where i could turn it on, i could hear the fan and disk spinning but the screen would stay black and blank. The keyboard lights and wireless connection light turned on, but they wouldnt respond to being switched or touched.
I read this solution, I thought it was bogus, but it was worth a try rather than sending it back for its warranty. I promise you this worked for me.
Ok...
1. make sure the power is off
2. make sure the lap top is not plugged in (charging cord is not plugged in)
3. remove the battery from the bottom
4. hold the power button for 30 to 60 seconds
5. plug in the power cord
6. turn it on as usual
good luck
Posted on Sep 29, 2008
  • 1 more comment
  • moth1976 Dec 05, 2010
    Totally worked! Thanks
  • timili
    timili Jan 12, 2011
    Unfortunately, even I have a HP pavillion DV6 series Laptop. When the laptop warranty ,which I got when I purchased my laptop, was about to expire I called HP support to renew it but they declined citing that HP has stopped issuing warranty for DV series laptops. I knew then and there that this Laptop is a Piece of Sh...t.
    I have been using my laptop for two years and there has not been any problem except
    -> it gets heated so much I can use it as a room heater.
    -> towards the end of the second year ( after purchase) the laptop would just show a black screen and become unresponsive if I used it for more than two hours at a stretch.
    How I tackle this problem:
    -> I purhased a Laptop cooling stand ( i got it for 100 rs in Bangalore) , it is a stand with some fans attached which definitely cool the laptop.
    With this cooling stand even if I use my laptop for gaming and play for 10 Hrs straight it will not heat up and will not show the black unresponsive screen.
    hp pavilion dv6000 LCD screen replacement:http://www.papatek.com/hp pavilion dv6000/
  • poorlady716 Sep 18, 2011
    I read on anther website the same solution and it worked for me also. Never shut down or power off the computer is the best solution so far. Also one solution I tried was ctrl+alt+del as soon as you hit the power button continue hitting those buttoons until you see the HP logo and stop. Hopes this helps. Ladydi
Make sure that the laptop is off, then detach the battery, hold the power button down for
(60 seconds) then power up the laptop from wall outlet it really works, great job
Posted on Nov 13, 2008
  • 186 Answers
First, try these steps :
1. Disconnect the AC Adapter.
2. Remove the Battery.
Note : Please see that there are no external devices or cables connected to the Notebook.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
If the above instructions doesnot work, try removing and reseating the RAM sticks in the Notebook by following the instructions available from page number in the Manual of the Notebook :
http://h10032.www1.hp.com/ctg/Manual/c00737799.pdf
Try starting the Notebook with one RAM module inserted and do try by inserting one RAM stick in another.
Additionally, you need to try connecting any Desktop Monitor to the VGA Port of the Notebook, power it on and press the FN and F4 key to get the display on the Desktop Monitor.
If this works and you get the display on the Desktop Monitor, the issue is with the LCD Display of the Notebook.
Unfortunately, if there is no display in either the LCD of the notebook or the Desktop monitor connected, the issue can be with the Hardware of the Notebook...
By the way, your Notbeook may be one of them in which there is a hardware issue discovered and if it is, you can get the Notebook fixed for free...
Get the Product Number of the Notebook which can be obtained from the bottom of the Notebook which is indicated by P/N and try to search it from the link provided below :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01300427&dlc=en
If the Product Number of your Notebook is listed in the link above and if it is purchased in US, you can get it repaired for free where you need to contact HP Chat Support.
Find more information from the link below :
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Hope this helps...
Posted on Aug 18, 2008
I have the same problem with my DV6000. It never got fixed. I sent it in to HP and they claim I have water damage on the notebook; which of course the notebook is never been anywhere near water. So HP is bullsh*ting. I would highly sugguest any NEVER BUY HP products!
Posted on Sep 19, 2008
Thankyou so much, the
WORKED!!! Thankyou
Posted on Oct 19, 2008
Hi, I had a similar problem with my dv6311eu, the screen just stayed black when I switched the HP on. What worked for me:
Take a hairdryer and heat the fan directly (underside of notebook) until it overheats and the system shuts down automatically, then restart (takes a few seconds before the notebook reacts again) and everything works perfectly ;)
Posted on Feb 17, 2010
  • Jdoops
    Jdoops May 13, 2014
    boi.. i had my bb gun pointed at the screen, then i read this and no other way to say it. but you saved me!
Here the same problem: laptop hp dv6000 is starting up, blackscreen, reset, over and over. After reading all the post about this topic, I started to disassemble the "thing" because it's a worthless peace of .... When removing the keyboard and the power strip, I saw that the fan was very dusty and therefore I took the vacuumcleaner and cleaned with a lot of wind getting through the inside of the laptop the dust. Then I tried the do a start up and guess what: worked like a charm. After closing the case it still worked. But while installing Ubuntu I saw the video (I guess because of overheating) crashing. After the crash it did the same as on the start of my story. Again the vacuumcleaner was helpfull. When a lot of cold air passes the inside of your HP the problem is gone. Therefor I made an USB fan that is blowing cold air between the laptop and the table. Next step is to put something between the laptop and the table to get even more fresh air. It's stable now for a while. So instead of destroying or shooting your laptop (as I have seen on Youtube LOL) just cool it down. I hope this works for you all. :-)
Posted on Jan 24, 2010
I had the same problem with my DV6000 laptop and i solve it, first make sure every thing off and you have to open the Hard Disk carefully it's on the bottom of laptop and don't touch any avio. hardware just take the small battery out and return it again and start yor laptop and it should work if dosen't.
again go to the same HD and open it and take the RAM out but very carefully in this time. you'll find to slide of RAM just take out and return it again without touching mide of the RAM only the edge of the RAM and close every thing out and start your laptop and in this time should work. good luck.
Please tell me if it's work on my Email : saad_nm@yahoo.com
  • saad_nm Feb 01, 2010
    thebajabum
    Try solution # 6
  • saad_nm Mar 06, 2010
    Try Solution # 8
Thak you SOOOOOOO much!!!! It really works and you saved us so much frustration! Thank you thank you thank you!!!!! 1. make sure the power is off
Posted on Oct 12, 2009
I have the same problem. When I try to do a repair it finishes with a blue screen and the mouse appiers again. However, nothing is fixed. I tried to do a re install of vista and it hangs every time.
This in my second HP with problems. The other laptop has a short in the monitor so I have to wiggle it til it stops.
I will NEVER buy an HP again....promise
Posted on Dec 08, 2009
  • hydro2000 Sep 26, 2010
    i took the small battery out from inside the laptop then reinserted it
    then i powered it back up
    took awhile then it came on
    and ask to s run a reapair
    which i did
    and now its working ..
    .( if u wondering where the battery is its at the bottom where the memory chips are)
    New Friend:
  • 17 Answers
The problem is a damage to the MB by excessive heat produced by Nvidia GPU. The only way to fix this permanently is to take out the MB and reflow the GPU with heat. You can find a video on youtube how to do it. You must take out the piece of gel between GPU and cooling unit and replace it with copper bar or penny made prior 1983 - still made out of copper. Also clean the fan. Use heat transfer paste like arctic cool - not a glue, on both sides of the penny. Install win7. Win7 does not use the coprocessor and will help to ran the notebook cooler. Install speedFan 4.40 - free utility to see what the temp is of your GPU and CPU. If you did good job it will stay around 55C. If your HP notebook is still running check the temp. If the GPU is running 80C or more it will melt the connections on the MB and quit working sooner or later.
Posted on Apr 21, 2010
    New Friend:
For those who could not make it work with the power button hold, battery take off procedure, here is a fix. Power on the laptop, hold the function key and repeatedly press the video button(mine is on f4 key). this will bring the screen back on
Posted on Jul 28, 2010
  • 4 Answers
This happened to me the other day, I have a dv6000 series hp laptop... the screen kept cutting out on me... and then the fan went out. Well i went and ordered a new fan from expresstechnologies.com for 20 bucks. Ok so i downloaded the pdf file for the manual. Read over it and got to work. I have to problems whatsoever tearing my laptop apart. Read the service manual and TAKE YOUR TIME!!! Well anyway to the SCREEN FIX PART. There are two plugs behind the hp logo on the inside of your lid near the speakers. The plugs disconnect after a while from carrying the laptop around. All you have to do is get your lid off your laptop and take it apart and re-connect the wires. It is a guaranteed fix!
Any other questions let me know.
t.edward87@yahoo.com
Posted on May 30, 2009
  • 87eddie May 30, 2009
    the problem with the the hp dv6000 is that the wires on the inside always come disconnected.
    http://h10032.www1.hp.com/ctg/Manual/c01...
    read how to take your laptop apart... follow step my step and connect the wire from behind your screen.
    It happend to me and that is what the problem was... it was pissing me off for months.
  • 44 Answers
If you have black screen and three beeps, one long and two shorts, problem, please email me goaxer@gmail.com
I know easy fast and cheap way how to fix this problem. Just email me and I will explain everything in low price. With my method I'm using my computer about half year.
My method just fixing problem with black screen and three beeps, one long and two short.
Posted on Jun 07, 2009
    New Friend:
I have the same problem with my dv6000. It was lying around unused for a year now. Last weekend another of my HP laptops broke so I thought lets try the dv6000 again. Ofcourse it wouldn't start. I got the long and then 2 short beeps.
By accident i blocked the fan outlet. So the laptop fan was spinning very hard after a few minutes. I turned it off and then pressed the start button again. And then the laptop started as normal. So when the inside of the laptop gets overheated, then it will start after you turn it off and on again.
Posted on Jul 26, 2010
I got the same issue with my lap (hp dv6000), Yesterday i turned it on, and sudenly the arrow stoped moving, it was like a verrrrrrrrrrrrry huge lagg, so i shutted down the lap by pressin' on the TURNING ON button, and then i tried to open it again, it turned on but the screen was black and the wireless button was lighting red and also the volume button did...It seems laggy...idk..now im on my mother's lap and idk she doesn't let me use it much...so i hope that someone will give a solution soon :...thank u
Sandra.
Posted on Jun 01, 2009
I had a similar problem and what i did was removed the battery and make sure the power cord was not connected.
Posted on May 29, 2009
    New Friend:
(Model no HP dv6000) I have the same problem . i am not getting anything on screen except some lines and pixels. The screen is white and after some time its being changed to black as if something burning inside.
I am desparately looking 4 help .If anbody has any clue please help me on manishk223@gmail.com. I am student of final year and taken loan for study. This laptop was also under loan...but now in final year i am leaving without laptop and so i am fucked up in everything whether project or any presentation. because my parents are not in a position to buy me a new laptop. so please friends help me.
Thank you looking for response
Posted on Sep 02, 2010
    New Friend:
This is a group for anyone who has faced problems with hp products specialy laptops. One defect of the Hp pavilion laptops ( DV 2000, 6000, 9000) is the motherboard problem and VGA ( graphics card ). Perhaps together we can bring this aware to HP.‎
http://www.facebook.com/group.php?gid=110390745653221
Posted on Apr 02, 2010
    New Friend:
Hello, i have this balckscreen probelm on my hp dv6.first , i tried the 60 sec trick but it didn't work so i put my laptop in my wardrobe for 2 weeks and turned it
on but the screen remained black then I retried the 60 sec trick and it worked this time .but in the evening of the same day i turned it on but it showed black screen like before .so what is the real cause in this case ?IF YOU GOT ANY SOLUTION PLEASE CONTACT ME ON OKAYDOAKY@HOTMAIL.FR
thnks
Posted on Jun 15, 2011
    New Friend:
Hello I wondering how to fix my Hp pavilion dv2000 entertaintment labtop black screen
Posted on Feb 17, 2011
Solution 17 is the best, others are just temporary solutions.Clean the dusts first of all. After you did it I would recomend you to install windows 7 which has video driver on its own and never again intstal genuine NVIDIA driver. Or keep your system but uninstall NVIDIA drivers and sell your computer. Or connect your laptop to external monitor and uninstall NVIDIA drivers.
It works on my dv6000 laptop and black screen does not comes back more than 3mths since I did this.
Another solution: you can change the motherboard £70 (still cheaper than to buy any other entertainment laptop) if you know how to do it, if not take hammer film everything and upload to youtube.
Hope this will help you.
Posted on Feb 01, 2010
    New Friend:
    Problem Solver:
  • 9 Answers
Hi Friends,
HP Pavilion DV6000 Notebook main problem's are Power Problem, Vista Error etc..
For these problems you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here
Posted on Oct 08, 2010
I have a similar problem. My HP DV6000 display goes blank while I am working. I solved the issue by simply using the sleep function (fn key+f5 or close the laptop lid). After the it goes to sleep, just hit any key and your display should be back.
Cheers Vj Kolaventy
Posted on Nov 19, 2008
  • 4 Answers
HI, I HAVE THE SOLUTION FOR BLACK SCREEN FOR HP DV6000 AND 9000 YOU NOT NEED TO REEMPLACE THE MOTHERBOARD OR LCD. JUST LET ME KNOW AT shaline_22@hotmail.com AFFTER YOU FIX YOUR LAPTOP U HAVE TO MAIL ME $ 20US DOLLARS AS GIFT..OHOHOO
Posted on Jun 14, 2009
4 Suggested Answers
SOURCE:
Nicolomd
  • 84 Answers
SOURCE: hp pavilion dv6000
This is a manufacturer trouble.
Starts with WiFi troubles, then no screen and no start with 1 long and 2 short beeps.
Here are those who came with same problem>
http://www.tabletquestions.com/notebooks/53305-hpdv6000-beep-codes-no-display-startup.html
Hp resolve this problem by changing the mainboard on good warranty notebooks
i have the same problem but can\t go to the supplier, had no warranty.
icq 475653626
Posted on Jan 04, 2008
SOURCE: hp pavilion dv6000 screen goes blank 5 minutes after startup
i cannot install win xp on my hp pavalion it is already contain win vista and hard disc is SATA type give me a solution
Posted on Sep 08, 2008
SOURCE: My HP Pavilion dv6000 keeps restarting with blank screen
I have the same problem with my hp pavilion! ive tried everything and cant get anything to appear on the screen. Keeps rebooting every 15 sec or so. Did you ever find a solution to this?
Posted on Jun 09, 2010
Hp 650 blank white screen
You may want to check using an external monitor.
The DV6000 series unit have problems with Video GPUs processors. If you have experienced any other kind of issues like the WiFi not working ect. you may have a bad GPU.
Try re-seating the GPU with heat gun ( View on Utube )
Hope this helps
Apr 09, 2014 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Black screen hp pavilion dv4000
not sure on this for sure but it sounds like what the dv6000 did or does and the motherboard needs replaced.
Sep 12, 2013 | HP Pavilion dv4000 Notebook
My hp laptop dv6305us screen is blank power light is on but screen is totally blank.
The DV6000 series of notebooks are known to have problematic motherboards. Try the below options:
1) Hold the power button down for 5 second and the machine should shutdown. Then power on again.
or
2) Flip the laptop over and switch the "lock" switch to "unlock". Then flip the release button to remove the battery for a few seconds. Put the battery back in and try to power the laptop on.
or
3) Power on the notebook like normal. Watch the Hard Drive activity light (the one that looks like 3 stacked plates), if the screen is blank and the activity light is solid or flashing, you know that the LCD screen is bad and needs to be replaced. If that light is not flashing then the problem is your motherboard and it needs to be replaced. Call HP and ask them if your model was part of a DV6000 series recall, if so your repair costs might be covered.
Regards,
Jacob
Mar 05, 2011 | HP Pavilion dv6305us Notebook
Hp Pavilion dv6000 Blank screen. okay So My
Not for the faint hearted but here's the fix.
http://www.youtube.com/watch?v=JEpnqhRYGLw
They do appear to offer a good repair service a well at what seems a good price.
Jul 21, 2010 | HP Pavilion dv6000z Notebook
Mar 12, 2009 | HP Pavilion dv6000t Notebook
Hp pavilion dv6000 power is on but screen is in blank
Are there any beeps following? If there is one long and two short, then is a graphic card problem and you'll have to take laptop to service.
Sep 11, 2008 | HP Pavilion dv6000z Notebook
Hp pavilion dv6000 screen goes blank 5 minutes after startup
Sep 08, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv6000
hi
Dude very simple, uninstall the graphic drivers completely and reinstall them.
do give me feedback
bye
yasir sardar
Feb 27, 2008 | HP Pavilion Notebook
Blank screen
motherboard problem or
ram problem
Oct 26, 2007 | HP Pavillion ZV6000 Notebook
HP Pavilion dv6000z Notebook Logo
70,001 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
