Master
- Posted on May 10, 2011
Re: Don't have the directions to put evenflo exersaucer...
Instructions
Place the large, round base on the floor. The outwardly curving edge should be facing downward.
Attach the three pedestals to
the base. To do so, insert your finger into each pedestal and loop the
spring within around the hook found on the base in the appropriate
holes. Insert the three plastic tabs on each pedestal into the base,
locking them into place.
Press the wider end of a lower
leg assembly onto each pedestal piece. By wiggling the lower leg
assembly side to side, you will eventually snap the pieces into place.
Hold the seat ring in your lap with the open edge facing upward. Press each of the six wheels into the wheel holders around the edge of the seat ring. Each wheel will snap into place when positioned correctly.
5
Insert the cloth seat into the
seat ring, aligning the diamond on the cloth seat with the triangle on
the seat ring. Each plastic tab lining the edge of the cloth seat
attaches to a peg on the seat ring. Snap these connections into place.
6
Hold the Exersaucer tray on its
side and press the seat ring into the center. Once the seat ring snaps
into place, it should be able to spin in place.
7
Attach the three spring caps to
the Exersaucer tray. These spring caps cover the three large holes in
your tray, and are attached by a firm clockwise twist.
8
Attach the upper leg assemblies
to the upper leg crowns. These crowns act as the "socket" and the upper
leg assemblies act as the "ball." By pressing them together with a
click, the upper leg assemblies can twist and rotate in place.
9
Turn the tray upside down and
press each upper leg crown base into the round holes in the tray with a
firm twist. Each upper leg crown features a height adjustment hole,
which will face outward when properly attached.
10
Turn over the tray so that the
upper leg assemblies are facing downward. Insert each upper leg assembly
into a lower leg assembly, being sure to pull away the height
adjustment tab to allow the assemblies to slide together.
11
Press each toy into its
respective port on the surface of the tray. The toys each have a
distinct base, which clicks into the correspondingly shaped tray port
