Some compressors/condensers can be re-gassed, depending on what the problem is! Can be soldered and gassed etc...ask around..
If you were told to replace the entire compressor unit (condensing unit), the person diagnosed the compressor is most likely bad. Depending on the age of the unit, it is hard to tell if this is a good decision. Overall condition plays a role in the decision process as well.
SOURCE: I got a true refrigeration sandwich prep table it ...
Look for doors not properly closing, poor air flow over coil or something blocking air flow, improper freon level.
http://www.truemfg.com/pdf/InstallManuals/TPP_TSSU_TUC_TWT/tuc_english.pdf
check out this web site as it has a manual for your equipment. it has lots of good info. Hope this helps. If you need more help, let me know.
SOURCE: why is my fogel sandwich prep getting too cold
Hi, There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems. Refrigerator is Too Cold and Freezing Food heatman101
