Uninstall it using administrator password
Unfreeze your system by holding SHIFT and DOUBLE CLICKING the deep freeze icon in your system tray, then entering your password and choosing the unfreeze option. After rebooting, run the installer you used to install deep freeze and choose the uninstall button.
Your machine will reboot, and Deep Freeze will be uninstalled.
Deep Freeze is installed on my computer. I would like to uninstall it. How is this done?
Disable Deep Freeze before uninstalling it.
To disable Deep Freeze:
Hold down the shift key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6.
Enter your password and click OK.
If you have not yet entered a password you should be able to click OK without entering a password.
The Boot Options dialog is displayed. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
Reboot your computer. After the computer reboots, you are ready to uninstall Deep Freeze.
To uninstall:
Locate the installation file you used to install Deep Freeze on your computer. By default, the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
Run the installation file (DF5Std.exe or DF6Std.exe).
Select the option to "Uninstall"
Deep Freeze is uninstalled and your computer is rebooted.
What if the device is a Ziio tablet?
Deep Freeze Enterprise makes PCs indestructible. It protects endpoint computers by freezing a snapshot of the desired configuration and settings of the computer from a computer. An immediate reboot removes unwanted or unwanted changes from the system and restores the original frozen state. Deep Freeze Enterprise Assign the desired status to your desired endpoints. Get unexpected changes with a simple reboot.
Schedule various maintenance windows to perform automatic updates using a batch file or third-party management solutions to install Windows and other software updates. Perform actions to restart, shut down, and enable the LAN for on-demand or scheduled execution. Or, download Deep Freeze Enterprise and remotely lock the keyboard and mouse to prevent unauthorized changes. Give users unrestricted access and avoid restrictive computer locks for security reasons. The reverse configuration can be changed by simply rebooting while users can save their work.https://hdlicense.com/deep-freeze-enterp...
SOURCE: i forget the deep freez password
Oh!!
You have to Re Install your Operating System now. There Are no More Options left g\for your after forgot ting password. If you using license product then contact deepfreeze Devlopers to get help.
Thanks.
Happy to help you.
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To uninstall:
