I was given a drups espresso machine but it has no instructions, I have no idea how to use it. can you help?I was given a drups espresso machine but it has no instructions, I have no idea how to use it. can you help?
AnonymousMar 17, 2014
water won't flow through machine, just boilswater won't flow through machine, just boils
AnonymousMar 19, 2014
water leaks under machinewater leaks under machine
AnonymousMar 28, 2014
thermodiscthermodisc
AnonymousMar 30, 2014
the group gasket broken Krups expresso machine. I am not sure if it is a gasket or just a part that holds the small basket.the group gasket broken Krups expresso machine. I am not sure if it is a gasket or just a part that holds the small basket.
You can't post conmments that contain an email address.
Look for a defective heater, thermostat, safety thermal fuse, or a possible interconnecting wire is broken. This not considered a homeowner repair as it involves mains power and if the safety fuse blew, something made it fail. Because this is likely to be fairly expensive to repair (at a service shop), you should get an estimate and compare that to a new machine. Hope this helps!
turn on your krups espreeso to warmup the water, put one spoon of coffee in the handle, lock the handle and turn on the pressure button, and the coffee leaks in your cup, that's all
Hi. Was searching around and you can actually go to the krups website(www.krupsusa.com) and download the appropriate manual for your coffemaker. Its best to know the model number as well as the model name. On the Bistro, the coffee maker side should be on the left and the expresso side on the right. on top of the coffee maker on the right side is a screw on top(black in color depending on year of model). Simply unscrew and fill with water to recommended lvl. I would download the instructions first and become familiar with the process as it heats up the water to extremely high pressure and heat. Good luck..J
INstruction manual
thermodisc
