Refrigerators Logo
Posted on May 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 253. 9287413 Can't get the freezer to get cold enough. Freezer alarm keeps turning on and the temperature is only 25 degrees inside. Temperature alarm light stays on all the time. Quick freeze doesn't seem to do anything except turn on the green light.
Anonymous
Level 3:
Genius:
  • Master 1,156 Answers
  • Posted on May 10, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1156
Questions
0
Helped
278137
Points
3203
You can fix this, just follow the procedure given to enable get back your refrigerator going,
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
I hope this will help in solving the problem......
2answers
Kenmore upright freezer. The alarm keeps going off?
The light may be staying on and creating heat, or the unit thinks the door is still open.
Or the door seal is worn and is letting cold out.
Or
It needs gas.
Have you put a thermometer inside to check the temperature? It should be 0'F +/- 2'.
https://www.google.com/search?q=Kenmore+upright+freezer.+The+alarm+keeps+going+off
1helpful
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
2answers
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Temp Alarm going off and not very cold inside.
I think you should see if the circulation fan is working inside. Sometimes they need a little push and some WD 40 let me know. I might have another idea. The Raz Shack
1helpful
...The temperature in the frig is now + 40 degrees
uve probably got a freon leak check to see if compressor is running and fans inside are blowing if so then u probably have a freon leak
2answers
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
1helpful
Proper temp. range in freezer
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
2helpful
MY FREEZER IS GETTING TOO COLD AND THE FRIDGE IS NOT GETTING COLD AT ALL
In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
2helpful
Kenmore frostless 19 temp. control knob
i've pulled up the service diagram for it and there's no thermostat or temperature control but there's a limit sensor inside the freezer I'm sure that such sensor is failing and when it defrosts, it stays on to long, and the whole 15 min defrost cycles goes on causing the freezer to warm up, delaying the freezing process. I'm almost sure that the limit is going.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
