Remove the cartridges,switch on check initializing or not if initializing put cartridges one by one & find out which one faulty, if not initializing replace formatter...
Hello
I believe the ink cartridge should have ink but not sufficient for printing, if the cartridge is expensive why dont you re-fill it, re-filling is very low cost option.
Also clean the contacts of cartridge from both ends.
Hope this helps, if so do rate the solution
Good Luck
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
hi
it's show u a red/orange light blink it's show u hae a refield cartig insarted u need to press red light buttons for 5sec. and then light blink off and only green light only show now give pring if again orange light blink press 5sec. don't give any kind of link on show messages in windows it's gone automaticaly if u have any quary please tell me...
The printer is working again - I exchanged the ink cartridges yet again, and finally the printer accepted them. Still don't know why the problem developed.
take out the cartige and if you can take out the cartige holders ( try to reach for the place where the ink flows out) spray it with a glass cleaning solution and let it pass inside where the ink pases and believe it or not it will clean properly the ink passages. try to clean the bottom of the cartige too.
some 1 trid it infront of me and it worked.
ps: an unproper positioning of the cartige will cause the printer not to work.
