Computers & Internet Logo
Posted on May 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the security code for 2wire870, wifi - Computers & Internet
Anonymous
Level 2:
Scholar:
  • Expert 134 Answers
  • Posted on May 10, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
134
Questions
0
Helped
30688
Points
430
1. USER :Admin
PASS : Wireless
2. USER :Admin
PASS:1234
3. USER:Admin
PASS :Password
Jax Planet
Level 2:
  • Expert 923 Answers
Jax Planet
Expert
Level 2:
Answers
923
Questions
0
Helped
256030
Points
140
You need to contact the administrator of the WiFi network and ask them for the security code. After all, it wouldn't be much of a security code if someone published it in forum like this one?
Device has 5 bar conection on wifi on PC but won't connect to internet
I'm not exactly sure whether you are connected to the PC but can't see the internet or whether you are not connected to the PC. So I'll explain the difference and you can decide.
When you attempt to connect a device to a wifi network, the device will do a search for available networks. The networks in range will display, showing their SSDI (name), signal strength, and security status. This is not yet a connection, only a detection. To connect to the network, you need to select the one you wish to join and send a connection request. Unless the wifi network in question is a free hot-spot or is unsecured (neither a good idea to use), then the next thing that will come up is a passcode/security code popup. Here you must enter the passcode/security code that the wifi network is assigned in order to connect. Without it, you will not be able to connect or access the network or internet. There is also the issue of security type. Older routers and devices used a code system called WEP. Newer router use WPA/WPA2 encryption techniques. our device must support the security type the router is using or you will not be able to connect.
2answers
Why has my mobile phone WiFi stopped working at home?
Open your wifi on the phone and press and hold the wifi network that you want to connect to then click (modify) re-enter the security code for the wifi network again and then connect. If that does not work then the wifi signal is weak and you'll need to get closer to your router.
Another thing is to choose United States for your Wifi Region in the wifi advanced settings menu.
-- uncheck (avoid poor connections)
-- check scanning always available
-- Wifi Region Code (select United States)
I hope that helps
Wifi doesn't work on my dell vostro with xp
wifi doesn't work on my dell vostro with xp ?
you must have a wifi driver check it device manager goto start --> my computer -->right click then properties goto hardware tab check for your wifi driver is installed... find the yellow question mark... then try to install it...some wifi have a security you need to know the security code... ex. wep.. etc,.
HOPE IT HELPS GODBLESS!
I donot know the password to use wifi in phone
Hello sameer,
if you are trying to connect to a certain wifi specially if it is secured where in it is asking for a security code you need to ask the owner of the wifi network for you to log on to that network..hope it helpsv :D
My grandson has a DISXL and is trying to set it up for the internet. I am getting error code:051110-1. It is also asking for a security key. I need help.
do you have wifi? If you don't have wifi it wont connect. Plus if you do have wifi you prob. put a sec code in to block outsiders. so you need that same code to access your wifi
1helpful
My netbuk is wifi ready,wat is the 1st thing 2 di 2 conect 2 a wifi zone?
there some Wifi NETWORK that are security enabled while there are some that are free to air so if you actually want to connect wth your wifi you need the security code of the Secured Network;
and as for the NETWORK that is free to Air follow the Instructions Below..(also applies to Secured Network but with the Insertion of Code when you get to where it prompts you to insert your network code)
1. from your start menu button ,control panel, If you are using Windows Vista or Windows 7 Click on Network and Sharing then click on
2. Connect to a Network.
there you find the list of available network within your location.
I use wifi so i have to log in whats the code?
If your WIFI network has the security feature turned on you have to input that security code in order to access your network. That code was set by whomever set up the network. If you use the netbook on a network such as Mcdonalds their network is open to the public and does not need a code. Find out what your network code is or reset your router and put a new code in that you will remember.
I have a new laptop computer and am wondering how I log on to internet as it is asking for my access/security code?
I assume you are connecting thru wireless or wifi. If its asking for the security code then you have to know the security password for the SSID on that wifi router. Many Wifi routers have security passwords before you can access the internet. If you are connecting to your wireless router then just disbale the security password but will be disadvantageous because other people can connect to your router. Just ask the person for the password who initially setup your wireless router.
HOW CAN I UNLOAK AND USE WIFI SECURITY CODES
ha ha.. a tricky question! the only option is to get a wire connection to that router, get the security key, and go online!!
Someone on my network
We need to first determine what type of WiFi device you have in your home because each has a little different method of creating security. It would be best to create a security code for your WiFi connection that way only the people you give the code to can have access. Keep in mind there are different types of security codes to deal with. The more basic types of security may be easier to decode by a "hacker" but allow the least amount of work by your own computer. Whereas, the more complex security means much more privacy for you but a little more work for your laptop.
There's also the suggestion of making your WiFi "name" something clever and non-guessable, connect your MacBook to it, save it as a preferred network and then disable the "radio" on your wireless router. this will allow your WiFi network to continue working, but it is not constantly broadcasting your network name to your neighbors. They will now need the actual NAME of your network PLUS the security code you've enabled.
Many remote support technology companies, including me, are able to use your Internet connection to connect to your computer and then secure and configure your WiFi device for you if you're not comfortable doing the things I've outlined.
Grand Canyon Tech
Grand Canyon Tech
