The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some
microwave oven doors.
This is not difficult. To access the door handle mounting screws on MOST
microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and
work your way slowly around the perimiter of the glass. Most
microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful
microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually
work your way around the perimeter of the door glass and make sure it snaps back into place.
NOTE: If your microwave is the same model you have this listed under, I could only find one website that offers the handle as a separate replacement without purchasing the entire door (the entire door cost over $200!). The handle lists for about $51 at repairclinic.com. You can search around, but I have already tried the following sites:
appliancepartspros.com
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
I hope this helps you.
