Philips GoGear SA3125/37 MP3 Player Logo
Posted on May 09, 2011
How do I add music? - Philips GoGear SA3125/37 MP3 Player
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on May 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
2979
Points
45
Here Goes:
  1. Plug in the Philips mp3 player to your computer. Use a USB cable to make the connection so you can begin synchronizing your music collection.
  2. Start Windows Media Player. Depending on how your computer is set up, this program may start automatically when you make the connection with the MP3 player
  3. Find the Sync tab in the media player window. Click on this tab and open the Sync screen. The Sync screen has two panes. The left pane is for the music collection on your computer; the right pane is for the Philips MP3 Player
  4. Choose the songs from your collection that you want to add to theMp3 Player's memory. Check the boxes that are presented by each song title
  5. Click the "Start Sync" button. The files from your computer are being copied onto your MP3 player.
  6. Wait for the sync to complete. You can monitor the progress in the "Windows Media Player" window.
  7. Close the media player program. Unplug your Philips mp3 player from the computer
  • NOTE: If this doesn't work you might be able to see your player in the MY Computer window.(after you connect it via USB cable) Select the player copy the songs and paste them into the player. Safely remove the device. You should be able to play the songs ..
How do I connect iphone 5c to my pc
You can resort to 3rd-party iOS data transfer tool - Leawo iTransfer to help you to transfer music from PC to the iPhone 5C. Just check below steps.
Step 1. Run Leawo iTransfer and connect iPhone 6s to computer with USB cable.
Step 2. Add music you like from computer to iPhone 6s.
Note:There are 5 ways to add files from computer:
A.Drag and drop the computer files directly into the window of the software;
B.Right-click music library and choose "Add File" or "Add Folder";
C.Click "File" on the upper right corner, and choose "Add > Add File/Add Folder";
D.Right-click music library and click "Add File";
E.Click "Add" button on the top left, then choose "Add File" or "Add Folder".
Step 3. After adding music to the software, it will automatically begin to transfer music from computer to iPhone without iTunes.
Of course, as a dual-way iPhone transfer tool, excepting for transferring music from computer to iPhone, Leawo iTransfer also allows users to transfer music from iPhone to computer for backup.
transfer-music-without-itunes-vd3ghtq0otun1p5ueq32suwi-5-0.png For more details, check: How to Transfer Music from Computer to iPhone
I cannot import any new media (music). The Zen Media Explorer attempts to import songs but then does not transfer any files, with the message " there is insufficient space on player." However,...
dude well da case is simple wot ur tryn to do is add da music in da player to da player again, da player already is fuull wit around 4 gig so nly 3.5 is around is free so u cant add da same music again........ since is not enough space kkkk if u wann add more new music search da computer using the media explorer and add the new music to the music library and sync it with da player if dis doesnt work mail me your problem with further details.... kkkkkk [email protected]
How to add custom music to my video
You could use some program which give you picture and music together maybe.
2answers
How can i download musics from computer to iphone
The easiest way is by utilizing iTunes. And you can resort to the 3rd-party iOS data transfer tool like Leawo iTransfer to do that. Just follow below steps.
Add music without itunes .
As you see, sometimes, iTunes is not so convenient for transferring music. However, you can try an alternative to iTunes - Leawo iTransfer. It's easy to use and without sync with iTunes. Check below steps.
Hw to put music in iphone
You can try Leawo iTransfer. It's easy to use and capable of transferring up to 12 kinds of data. Just follow below steps. Step 1. Run Leawo iTransfer and connect iPhone 6s to computer with USB cable.
For more details, check: How to Unlock iPad?
How can i put music on an unlocked iphone?
You can try to reset the iPhone and connect to iTunes again. Or just utilize Leawo iTransfer to reach this aim. Follow below steps.
Add music
transfer music
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
