Question about Lexmark X7350 All-In-One InkJet Printer
When i ask to print all (pages), only the last page gets printed. I have to select and print each page separately to print out whole documents. I'm printing from an Hp using windows Vista 6.0. This is a recent problem, but I can't trace the problem back to when it started occurring.
    Scholar:
  • 118 Answers
Some printers collate pages, which means they print from the last page to the first page. so that when you pick up the pages from the finished printing tray they are in order.
if you say it stops after the first page, there are a few possible reasons for this.
either you closed the application you were printing from before you finished printing (which sometimes cancels the printing job)
or the computer decided it wanted to cancel the printing on its own, this can happen if the printer has sometimes an error, this error or cause could be a lag between the data transfer to the printer.
try printing without collating the pages, while keeping the application/document open.
and make sure you have the latest drivers.
Posted on May 09, 2011
6ya staff
SOURCE:
Xp word 2002 will only print first page of 4 page document
Be sure to select PRINT ALL instead of PRINT CURRENT PAGE
Jan 22, 2013 | Office Equipment & Supplies
Tip
Printing Sections in Microsoft Word
Printing Word Documents with Multiple Sections You have a document with multiple sections. When you try to print specific pages, you get either one single page, or the whole document. What you don’t get is the two separate pages you need.
First, take note of which section has the first page you want to print, and in which section the second page resides.
You need to print Page 2 of Section 1 and Page 1 of Section two.
In this particular case, the command is the usual: File | Print:
The difference in this case is how you specify the pages to be printed. In the Pages dialog box, type P2S1, P1S2 and then click OK. The comma “,” separating the two pages indicates two separate pages. The result will print Page 2 of Section 1 and Page 1 of Section 2.
If, however, you wanted to print from Page 2 of Section 1 through and including Page 1 of Section 2, the command would be P2S1-P1S2. The dash "-" indicates a range of pages, which results in printing from Page 2 of Section 1 through and including Page 1 of Section 2.
on Mar 26, 2010 | Microsoft Word 2003 for PC
Whenever I print from there is an extra page that prints after that includes: Filename: Directory: Template: Title: Author: Keywords: Comments: Creation Date: Change Number: Last Saved on: Last...
when you go to "print" a box should open asking if you want to print "all" or "pages" . click on "page" and then click "1" then you wont get the trailing page.
Feb 21, 2011 | HP LaserJet 4200n Printer
How do I suppress a title page printed before the document?
When the print dialog box comes up, select page range, and input "2-xx" xx being the last page you want printed. This will skip page 1.
Sep 29, 2010 | HP DeskJet 612c InkJet Printer
Single page printing
OK, well when printing from the internet it quite often only prints the screen you are on, I presume, because you likes what you read, you wish to print it, well as you are on Page 3 the end of the document, thats what get printed. You actually, need to go to the File Menu, select, Print, and actually select, the type of print, there are options, Print ALL, Print Page, Print Selection, you need to set that, it sometimes remembers a setting and perhaps 3 was the last setting.. In any event don't just "Hit Print" you have to do as related, I am not sure if you can set up special "Print Now" parameters, but I expect you can, choose a "Default" setting.
Mar 31, 2010 | Lexmark X5650 All-in-One InkJet Printer
When asked to print, it prints:Filrname, Directory, template, title, subject, arthur keywords, comments, creation date, change number Last saved on,Last saved by, Total Editing time, last printed on, I...
If you are using Microsoft Word, click Tools and then Options.
Once the Options windows pops-up, click the Print tab and UNCHECK Document Properties.
Document properties - Prints the document's summary information on a separate page after printing the document. Word stores summary information on the Summary tab (File menu, Properties command).
Nov 15, 2008 | HP Office Equipment & Supplies
I need to change printing pages from last to first page first
the last printed page is always on top. For a long document, it takes a while to resort and place the first page first! This is how you can get Microsoft Word to reverse the print order and save all the trouble.
I have spent so much time resorting documents after printing. On my printer, the last page printed is always on top. By printing the last page first (reverse order), the document is already correctly sorted.
Here is how to do it:
1. Open Microsoft Word
2. Open the document to be printed
3. Click the Tools menu
4. Select Options
5. Click the Print tab
6. Check the Reverse Print Order option
7. Select OK
Now, all your documents will prevent in reverse order. What a lifesaver!!!
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 30, 2008 | Lexmark Office Equipment & Supplies
Ricoh CL3100N
Have you setup for double-sided printing?
Jul 15, 2008 | Ricoh Aficio CL3500N Laser Printer
HP Officejet 4315 printer options question
Click on File and Print :
select the page range or number here as shown below:-
Hope it ll suffice ur need
May 12, 2008 | HP Officejet 4315 All-in-One Printer
Printing problem
ISSUE: A blank page prints after every print job using an HP LaserJet series printer. SOLUTION: A separator page may be turned on in the printer driver, within the application, or on the network. Try printing from several applications. If a page prints out in only one application, that application may have a summary page selected to print out. If a page prints out from different applications, a separator page may be turned on in Windows or on the network. Use the following sections to turn off separator pages. Windows 95/98/Me Follow these steps to turn off the separator page in Windows 95/98/Me:
  1. Select Start .
  2. Select Settings .
  3. Select Printers .
  4. Highlight the appropriate HP LaserJet printer icon.
  5. Select File .
  6. Select Properties .
  7. In the section labeled Separator Page, select None .
  8. Click Apply .
  9. Click OK .
Windows NT 4.0/2000 Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  5. Select File .
  7. In the Advanced tab, select the Separator Page button.
  8. Delete the location for the separator page.
  9. Select OK .
Windows XP Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  3. Select Printers and Faxes .
  5. Right-click on the highlighted printer icon and select Properties from the Advanced tab.
  6. In the Advanced tab, select the Separator Page button.
  7. Delete the location for the separator page.
  8. Select OK .
Software or applications See documentation for the specific application that is printing a separator page. The following steps are an example of how to turn off the summary page in Microsoft(R) Word 97:
  1. Open Word 97 .
  2. Select File .
  3. Select Print .
  4. Select Options .
  5. Deselect Document Properties in the Include with Document section.
  6. Select OK .
Novell environments Banner pages can be sent to the printer in several different ways in a Novell environment. The following instructions detail several ways to disable the banner page. NOTE: Banner pages can also be sent from the HP Jetdirect device itself. This page can be enabled and disabled through a telnet session to the HP Jetdirect device. The telnet banner will only print in an lpd/unix ® environment. Novell's Capture Command To disable a banner page using a Novell DOS capture command at a system prompt, type the following commands: capture L=x Q=queuename NFF NB NT TI=x where:
  • L = x -- The value of x would be 1, 2 or 3 depending on the lpt port being used.
  • Q = queuename - The value of the queuename would be the Novell queue setup for this printer.
  • NFF -- No form feed.
  • NB -- No Banner.
  • NT -- No Tabs
  • TI = x -- The value of x would be the timeout amount in seconds. NOTE: If the client workstation is restarted, and if a capture command is part of a login script that is being used, these settings will be reset.
Printer Properties The banner page for Novell networks can also be enabled or disabled in the Printer Properties using the following steps:
  1. To open the Printers Folder ; click Start , Settings, and Printers .
  2. Right-click the appropriate HP LaserJet printer icon and select Properties .
  3. Select the Printer Settings , or Capture Settings tab. The banner page can be enabled or disabled here.
NetWare Clients Follow these steps to disable the banner page for Novell NetWare clients:
  1. Right-click Network Neighborhood and select Properties .
  2. Select the Configuration tab in the Network window.
  3. Highlight Novell NetWare Client and select Properties .
  4. Select the Default Capture tab. The banner can be enabled or disabled here.
Feb 23, 2008 | HP LaserJet 1010 Printer
Lexmark X7350 All-In-One InkJet Printer Logo
108 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
