Have you tried soaking the shaft area with either PB Blaster or Deep Creep penetrating oil. Try this for a few days before trying to tackle getting the tine attachment off.
I would check that I didn't have a key sheared off in the flywheel, that the start/stop switch isn't faulty, and that there is no missing or weak flywheel magnet. Hope this helped and best wishes.
Check under the metal or plastic cover just behind the engine. This covers the forward and reverse belts. Your belt either broke, jumped off fthe pulley, or needs a tension adjustment.
If the seal fits over the axle shaft it should be ok. be sure your axles are very clean as not to ruin the new seals when applying them. probably a good idea to replace them as a pair (right and left side) to save you time down the road.
