Was the power on when you depressed the small switch? you mite have damage the lamp in the fuser or the control board. very old machine find the parts and replace them
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of
the 220V. Immediately the malfunction code (error code) of "C05"
appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found
the "Trouble Reset Switch" (not shown in the user manual) by opening
the upper back panel and pressing the small black button in the lower
right hand corner of the middle circuit board (green).
It worked perfectly!
SOURCE: Help! i get the "Machine Trouble" error
are you sure thats the right trouble code? reboot machine holding down the STOP button. this may reset this error
SOURCE: Minolta Error code C0500
1. Test Mode Operations
• The Test Mode is performed from the copier’s Tech. Rep. Mode.
1-1. Entering the Tech. Rep. Mode
1. Press the Utility key.
2. Touch [Total Check].
3. Press the following keys in order: Stop → 0 → 0
→ Stop → 0 → 1.
NOTE
• Be sure to keep the display procedure for the Tech.
Rep. Mode from any unauthorized persons not
involved with service operations.
4344S504CA
link to a service manual that explains tech mode
SOURCE: How do I get to Tech Rep Service Mode on Minoltas to clear C0500 error code?
To access service mode:
Hit the utility/counter button.
Touch meter count.
Type the following on the keypad:
<STOP> <0> <0> <STOP> <0> <1>
SOURCE: Code C0500
simulation = UTILIY -----> METER COUNT (on touch screen)->
STOP------> 0-----> 0------> STOP------>0------>1
