All thethe pieces go in atthe a 30 degreemin angle.
Triangles go around outside with longest sides going against the outer edge, shortest sides pointing counter clockwise, and 2nd longest sides facing the middle. Big triangle points toward little triangle.
5 little squares go in the middle to make a cross. Turn it 30 degrees so straight sides of crossthe are parallel with inner edges of the triangles around the outside.
The big odd pieces go between triangles and cross.
Set up your pieces on a black-and-white checkered game board with 64 squares of each color. Each player should set their 12 pieces on the 12 black squares closest to them on opposite sides of the game board.Decide who goes first by tossing a coin.Move a game piece forward diagonally along the black squares if you are the first player. You may move only one square at a time per turn and you must go forward on the board.
Take your opponent's game piece by jumping over it forward diagonally along the black squares if your opponent has one of his game pieces adjacent to yours and there is a vacant space beyond your opponent's piece. You may take more than one jump if you land on a space where you are able to jump another of your opponent's game pieces
Have a game piece crowned as a "king" if you reach the far edge of the board closest to your opponent. Your opponent must place one of the game pieces he has captured from you on top of your king piece to distinguish it from your other pieces. Your king is now allowed to move diagonally forward or backward instead of just forward.Win the game by capturing all of your opponent's game pieces,Hope this helps :D
