Question about GE Profile Performance WPSF4170WAA
My Ge washing machine is leaking from the Bottom
OK well I have owned this washing machine for about 8 years and it hasn't caused me any problems, until about for days ago. i noticed that now every time I wash my clothes, all the watter leaks out from the bottom. I don't know how to fix it please help me.
  • btonning Mar 25, 2009
    Pretty funny (or sad, depnding on how you look at things): I also have a GE washer purchased in October 2001 - 7.5 years ago. Never a problem until the other day, when we noticed a small but steady dripping from the underside of the machine. This begins at some point during the initial fill and continues through the entire load...
  • 734 Answers
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
SOURCE:
Why do the lights throughout the house pulsate when the washing machine starts agitating?
What make and model washing machine? How far is the breaker box from the washer?
Mar 24, 2017 | Washing Machines
My washing machine gets a greasy ring around the tub, and agitator. This has been happening for a few years. The machine is 7-8 years old. What could be causing this?
THIS COULD BE CAUSED BY THE FABRIC AND THE SOAP ALONG WITH THE SOIL.
IF YOU NOTICE THE FABRICS YOU ARE USING NOW ARE DIFFERENT THEN THE ONES YOU USED A FEW YEARS AGO THIS MIGHT BE THE PROBLEM.
HAVE YOU CHANGED SOAP OR STARTED USING A FILTERED OR ro WATER SYSTEM? THIS TOO WILL EFFECT THE WATER CHEMICAL MAKEUP AND COULD CAUSE THIS. ALSO DID YOU CHANGE SOAPS?
Jun 10, 2015 | Whirlpool Washing Machines
Why water drop before lever raised until top position?
\\this might be caused by a worn piston seal. see here how to replace seals.
dr pavoni
May 15, 2014 | La Pavoni Europiccola EPC-8 Espresso...
The inside of my Speed Queen washer smells badly . It makes my clothes smell also , but not near as much as inside of the washer . What happened to cause this ?? Also , the detergent holder never...
Front load washers seal up tight with door closed. This causes the smell. Leave the door open in between loads.
The detergent holder always holds a little water.
Nov 04, 2009 | Speed Queen CTSA0AWN Front Load Washer
Leaves white marks on coloured clothes
I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
Cheers
Mar 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 80 Series won't spin out
if the unit washes ,,and dont spins check your lid switch first...
Oct 25, 2008 | Kenmore 24902 Top Load Washer
WASHING MACHINE WILL NOT TURN BACK ONF
If you registered your unit with the factory you won't need a receipt. If you failed to register your unit,(naughty,naughty), your selling dealer is required to keep records of all sales and should be able to supply you with a copy of the receipt. If you unable to provide a proof of purchase document, the manufacturer's product information tag on the unit is required to show model#, serial#, and date of manufacture. any one of these methods are acceptable to a factory authorized servicer. All you have to do is make sure you have your factory warranty policy on hand to ensure your ownership rights.
Thank you for contacting me at Fixya,com and if you would be so kind as to rate my solution, I would be forever grateful.
Dave E. (Illeagle)
Jun 12, 2008 | Washing Machines
Kenmore Wahing Machine Motor Overheating
...same problem here. any answers?
May 02, 2008 | Washing Machines
Washing Machines Logo
15,672 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
