Does this problem (internet status off) happen even when you are not using x-lite?
It's very unlikely that it's the software disturbing the connection. I suspect your VoIP calls are interrupted because the connection is dropping, and not the contrary.
yes, some times happen if use a the regular phone
but the issues that when i use skype, it works normaly,..
sometime the voip with x-lite call stays for 2 mn and other for 9 mn max...do u think that maybe from the ISP has block the voip ?
thanks again
That is unlikely, but it's worth investigating on that side. Call the ISP hotline to get the answer.
It could also be linked to the quality of your phone line. Make some tests to confirm/infirm that hypothesis. Go to the command prompt and run some ping tests on websites like www.google.com or www.yahoo.com and look out for packets loss. It will give you some information about the quality of your internet connection.
I don't know the mechanics of x-lite, so I cannot state about it's use of your bandwidth. Calling your ISP about this issue might give you the right solution to your problem. I reiterate this : it's really weird that a software causes your modem to drop it's connection, but curious as it it, it might be possible.
If possible, try to modify the MTU settings of your modem/router, this might help.
