Question about Jura Capresso C1300 Coffee Maker, Espresso Machine
How do I get a on line service manual for my Capresso C1300? Thanks,
    New Friend:
  • 110 Answers
SOURCE:
Turning dial after choosing strong, we want 4 oz, but turning dial toward 4 it may goe to 5 and then up to 7 down to 6, up to 8, etc.
Operating Manuals - Jura Capresso Coffee Machines
capresso.125west.com/html/operating_manuals.html
Operating Manual Impressa F9 and F9 Limited Edition. Operating Manual Impressa F7. Operating Manual Impressa E8. Capresso C1300 Superautomatic ...
Sep 06, 2015 | Jura Capresso Impressa E8 Espresso/Coffee...
Tip
Hi, I found your description very interesting even though my machine is a Jura...
All of a sudden I had no steam and no water.
I could hear the pump chugging and trying hard, but nothing came out of the nozzle.
First, check to see if the nozzle is blocked. If it's not, try turning on the tap (faucet) and PUSH IT IN towards the machine.
If you now get steam and water, there is a quick fix.
Switch off the mains, unplug the coffee machine and take all normal precautions not to electrocute yourself.
There is a small cam on the (Part 9161205 - Faucet rod stem) which pulls the tap IN as it is opened and OUT as it is closed.
1] Remove the coffee container - there are two phillips screws only, and it lifts off.
2] Remove the top casing. There are two phillips screws either side at the front top, hidden by the door, one star head screw under the water tank, and one normal phillips screw under the water tank in a deep channel.
3] Take a look at the small cam on (Part 9161205 - Faucet rod stem) and see if it moves in and out as you turn the water/steam tap on and off. If it doesn't the plastic has sheared off. If it does move in and out - this is not the fix for you!
4] If it does NOT move in and out as you turn the water/steam tap on and off, find a small self-tapping screw and screw through the angled cam hole into the faucet rod stem. Pop the top casing and the coffee container back on and your machine is now fixed!
Now for a delicious cappuccino62e2053.gif!
on Apr 17, 2009 | Saeco Vienna De Luxe Espresso Machine
Service 8 on Capresso 1300
The gears inside are clogged with coffee grounds. The machine will need to be taken apart carefully, and the gears cleaned of the coffee. I just did mine a C3000, and you will have to be careful to remember how all the parts go back together. This takes a T15 hex key for the screws. Good luck.
Aug 30, 2009 | Jura Capresso C1300 Coffee Maker, Espresso...
Capresso C1300 LCD stays on stating "Hot water cycle necessary"
I had one that set for 6 months that had that problem. Air had gotten into the water lines. Opened the hot water tap a few times and then removed the end of the water line that runs from the solenoid to heater block to at the solenoid end to bleed air out. It could also have been some calcium deposits that blew out with the air blocking the line. Then I replaced the end of the line, powered the machine up and it worked normally. Note: Jura Capresso and Capresso machines are complicated and it takes some mechanical know how to open them up and service them. They also have four special screws on the back that requires a special tool to open
Feb 26, 2009 | Jura Capresso C3000 Espresso & Coffee...
Capresso c1300
I believe you have to go through the steps of running a hot water cycle which is on page 9 of the owners manual, 7.1 listed under "FIRST TIME PREPARATION" A. through F. If you don't have the manual, send me your e-mail and I can send it to you.
Feb 12, 2009 | Jura Capresso C1300 Coffee Maker, Espresso...
Capresso C-1300 not working
You can re-attach this brown flap youself if machine is not still under warranty (that would void the warranty) or if the tabs or flap is not broken. I have had this machine apart and have taken off the brown flap which have tabs on the top and sides that fits on the front(facing you) of the press (looks like a big white cog inside a brown case( I have photos). The thing is, taking the case off. Screws with special tops that requires specialized tools for removel of case. My husband had to use pliers very carefully to get these out and he said he will put regular same size back in. If you want the manual or photos, let me know yor e-mail.
Feb 03, 2009 | Jura Capresso C1300 Coffee Maker, Espresso...
MACHINE DOESN'T GRIND
you may need to turn the metal shaft with a pair of plyers to free it from sticking (this is a common problem)
Dec 17, 2008 | Jura Capresso C1300 Coffee Maker, Espresso...
Open Questions:
See all Jura Capresso C1300 Coffee Maker, Espresso Machine Questions
Jura Capresso C1300 Coffee Maker, Espresso Machine Logo
276 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
