Bryant 50 Amp 2 Pole Br250 Type Br Ni Circuit Breaker Logo
Posted on May 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a GE two speed motor/pump for a hot tub that I have adapted for a type of therapy called underwater pressure massage (all of the hot tub jets are channeled through a single hose for the high pressure underwater massage) Recently I took the motor to be reconditioned after it was tripping the GFI. Now the motor runs fine at low and high speeds under normal conditions. However when I switch the hot tub from the regular hot tub jet function to the high pressure underwaterpressure massage it trips the GFI after about 5 seconds. I went back to ask the repair shop for their opinion they said that the high pressure usage should not cause the motor to trip the GFI. Their suggestion; it might that repeated tripping the GFI before the motor was reconditioned may have cuased the GFI to become oversensitive and the Bryant 50 amp 2 pole breaker with GFI may need to be replaced. Is there any way to test this idea? Any suggestions on other things to check?
Fred Yearian
Level 3:
  • Master 5,603 Answers
  • Posted on May 08, 2011
Fred Yearian
Master
Level 3:
Answers
5603
Questions
Helped
2247545
Points
16162
Disconnect both hot leads from the breaker at the box. Using an ohmmeter measure the resistance to ground or the neutral bar in your box. If the resistance is LESS than about 50 K you have excessive leakage current. It is unlikely the motor is the problem. I would check the wiring and switching for the leakage. Now to the second problem: If you switch between speeds while the unit is running, the GFI will LIKELY trip. This is normal as you create a massive transient that the GFI PROBABLY can't handle. There are a couple things to try: One is using a two pole control switch and turn off the pump before "switching gears" ... as an electrical engineer I can't explain this unless you can understand electrical transients AND capacitive coupling between the windings and the case of the motor. I realize you may have a combination speed and on off switch so you MIGHT have to add a switch. Ideally I would want a relay for on/off near the breaker that momentarily disconnected before shifting gears. The next fix possibility involves a trick we use to control transients in electronics. This involves noise control by using a toroid around the pair of hot wires. This MIGHT take several turns through a good sized ferrite toroid with both the hots in the same direction, side by side. This forms what we call a "Bi-Filar" choke. Look that up on Google to understand the principle... it essentially helps balance the currents in the hots and isolates them from ground for transients.
Hot tub has low and high speed for jets. but they are always on. is there a way to turn them off?
not entirely unless you turn off the pump
the jets are the way the filtered water is returned to the tub
probably a problem in the micro switch that turns on the high speed jets
Jun 30, 2018 • Pool & Spa
Hot tub comes on jets want start
most hot tubs have two motors. one is a circulation pump to move water when the heater starts and the other comes on when the jets are being used. from the sounds of it, the one pump isnt running properly
Oct 20, 2015 • Pool & Spa
3helpful
2answers
Power trips out when jets are switched on
I'm going on somewhat limited information here not knowing if the tub is newly installed or if this is a spa that has been working in the past and just started doing this. It would be helpful to know if this is a recently installed pump as well. That said here are a few things to check.
If it's a new install: Your electrician has more than likely wired the spa incorrectly. Be sure that the spa pack has 220V going into the pack and that the GFCI is wired correctly.
If it's an old spa with a new problem: A lot of times a bad heater element can cause a spa to trip the breaker. If you have a bad element the spa will operate normally for about a minute when you turn the power on, then trip the breaker as soon as the heater kicks in.
If it only trips the breaker when the pump is turned on to high speed, more than likely there is a problem with the wiring of the pump or the relay on the pump itself.
Just looked at 2000 coast spa hot tub with 1 6.5hp motor,is this enough power to support the 30 jets as opposed to another hot tub that has 2 7hp motors with 40 jets
a 6.5hp motor produces quite a bit of force. It should be able to support 30 jets just fine. Most spas range from 2hp to 7hp. Depending on your preferences, the 6.5 should be plenty but if you really want a powerful therapy jet, two 7hp pumps should be more than sufficient. They will also kick your electric meter up a few notches...
Two pumps give you more options, you don't have to have half of the jets turned off so one area can have more power, the dual pumps give you the option to run nearly all of the jets at the same time if you have more than just a couple people in the spa a once.
How do you get the pump to circulate less. It seems like its running all the time to keep the temp up? I have a ozone system also could that be affecting it?
Your pump should be two speed if it is wired right there will be an overide in the way of a timer switch and or a therapy button ether one of these will keep the pump running at full speed the low speed should only run off the thermostat otherwise the water runs to fast to be heated properly. And no your ozone should have no effect on this. So check your timer and your therapy spa side.
5helpful
Difference tubs and air baths
whirlpool tub has jets that circulate the water, where an air bath uses bubbles that rise gently from the bottom of the tub. Whirlpools are typically used for therapy, air baths are used for a much gentler experience. Air baths can be used with aromatherapy/essential oils. Both offer a spa-like experience.
Top Bryant Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a Bryant Electrical Supply Expert? Answer questions, earn points and help others
