EnGenius EAP-3660 802.11b/g Wireless Access Point Logo
Posted on May 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost password,after reset (pressing for 5 second), admin/admin failed to log . Pl advice.
Andrew Calhoun
Level 2:
Novelist:
  • Expert 182 Answers
  • Posted on May 08, 2011
Andrew Calhoun
Expert
Level 2:
Novelist:
Answers
182
Questions
0
Helped
56744
Points
494
Some engenius wireless access points do not have a username password configured by default, so try it with the username and password fields both blank.
Sometimes, I have tried to reset the password on a wireless access point, and later figured out that I had failed to successfully reset the device. Make sure that the device is plugged in while you hold down the reset button. Hold down the reset button for 30 seconds instead of 5.
3answers
How do i reset the password to linksys wireless-g
You can reset the Linksys back to the default settings by -
Power up the Linksys, use a straighten paper clip and press the pinhole RESET button at the back of the router for 30 secs.
Open a browser and enter the configuration URL
http://192.168.1.1
The default login = admin
The default password = admin
2answers
Lost my password for d-link
You can reset the D-Link back to the default settings by power up the D-Link and press and hold the RESET button at the back of the router until all the LEDs flash.
http://192.168.0.1
The default password = blank (just press enter)
I had to reset my Linsys router because I lost my WEP key password and I got a new laptop and Now I am unable to log into the router again.
You can log into your router to obtain the WEP key. Usually if you type 192.168.1.1 into your web browser it will take you to the log in screen for your linksys router. The username will be: admin and the password: admin as long as it was not changed. If that username and password does not work then you will need to reset the router by pressing the reset button on the back of it for 10 seconds and then that username and password should work.
I forget the admin password for Toshiba_Estudio 281c, I follow your instruction to log in as admin using default password 123456 still can't access the Printer Web interface. how will i enter setting mode...
My advice? Sorry we are not affiliated with Toshiba in anyway. Anyways you can reset your router password by pressing the reset button(usually a hole into which you have to push a pointed object to press and hold it). Hold it for 10 seconds and you should be able to reset it to default.
Caution: This will reset all of your configuration settings too, but this is the only way to reset it as there is no otherway to see/change the password.
Sai.
5helpful
2answers
Forgot my password to my router had to reboot my computer so I lost and can't use router to get on-line
on the router there should be a little button press that for 5 secs and then release this will reset everything to fatory settings then you can log on using either
  • username: admin password: password
  • username: admin password: EMPTY
i hope i have helped you
I can not remember my password so i can use my wi fi. So how do i reset my password. i can log on to the router can i change it in the settings?
Reset
Pressing the Reset button for 5 seconds restores the router to its original factory default settings.
Log in to the Router
This section will explain how to log in to your router using the following steps:
1. Launch your web browser.
2. Enter the URL http://192.168.1.1 in the address bar and press Enter.
A login screen like the one below will be displayed after you connect to the user interface.
Note: There are three account types, each requiring a different username and password.
• The user account provides limited access to certain configurations (username / password: user / user).
• The admin account can perform all functions
(username / password: admin / admin).
• The support account is for ISP technicians for maintenance purposes
(username / password: support / support).
Note: Passwords can be changed at any time.
3. Enter your user name and password, and then click OK to display the user interface.
Note: This manual has been prepared using the admin user name
2answers
Need the security code for my network so i can add an other compu
Log into the router's setup page 192.168.0.1
Type in the password, the default password is admin.
Go to wireless Security and you will see your key there.
http://tinyurl.com/phexxc
http://www.ehow.com/how_2091715_obtain-lost-network-key-dlink.html
You can reset the router to default and set a new password and encryption key.
D-Link Router reset
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2answers
LOST MY PASSWORD FOR LOGON ??? .
  1. Press F8 on boot up
  2. select safemode
  3. when log in screen comes up log in as Administrator
  4. Once logged in go to Start
  5. Settings
  6. Control panel
  7. Users
  8. Select your user ID and select change password
  9. type in a Password you'll remember
  10. close everything out
  11. reboot and log in as normal with new password
1helpful
Zyxel prestige 660hw wireless router
Try using the password 1234.
If this fails look for a small hole in the unit, normally marked reset. Unit must be powered, press and hold the reset button for about 3-5 seconds, then release. Note:a tool may be required to reach the recessed button.
Then try the default login and password again.
Top EnGenius Computers & Internet Experts
john h
Krzysztof Tomasz
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
