Kenmore 22422 Top Load Washer Logo
Posted on May 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a Kenmore 20902 top loading washer. Does aggitate in wash cycle, but wont spin in rinse. With drum empty, it will spin. Removed cloths, rung dry by hand and returned to drum. Still would not spin, but I could see a light movement in drum. Gave a little assistance to get drum started spinning and did spin for entire cicle for duration.
  • perry_crista May 08, 2011
    where is the sence barring.
    where is the sence barring. Also noticed that with a heavy load, only the bottom aggitor works, but the upper part does not verry well. Is this part of the same sence barring?
Mike Cairns
Level 3:
  • Kenmore Master 3,054 Answers
  • Posted on May 08, 2011
Mike Cairns
Kenmore Master
Level 3:
Answers
3054
Questions
0
Helped
851024
Points
6358
Your drum is in a sense sitting on a barring , it sounds like your barring is going out. Works with no weight, and if helping as you said. Normally means barring is worn out and can not handle any weight.
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
1helpful
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
3helpful
I have a Sears Kenmore washer that sometimes does not spin in the spin cycle and sometimes it does. The timer progresses to stop, but clothes are still dripping wet. Resetting timer from spin usually...
The transmission in this machine is worn and is not shifting correctly. Understand that after the aggitate cycle, this machine should go into drain cycle without spinning and it should drain for about 1 minute. Then it should kick into spin cycle after it has emptied all the water. What is happening is it is (like skipping) the drain cycle and going directly into spin with water still in it,,, so the spin is slow as it is trying to empty and spin at the same time,,, thus the clothes do not spin out correctly,,, when you reset the spin, you actually spin all the water out the second time around.
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
2answers
WONT SPIN AT ALL
Is there water left in drum, and does it aggitate.
Kenmore 44092/spin cycle
It turns out that there was a sock stuck within the pump in the washing machine. I removed the back cover and removed all the excess water, because once the sock was removed, the water was free to escape. I just removed the hose that connects to the pump and felt the sock, and was able to remove it. Once I hooked everything back up, the washing machine ran great.
Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
LG wft7014pp wont drain rinse nor spin
do you have a drip-dry function...as this cancels the spin cycle unless you select it yourself
Kenmore 23832 top load washer
lalocke If the load is not properly balnced, your washer will shake too much on the spin cycle and it wlll never go on full speed. Gendos...post back
Alexander
vince
