If it is me and I am spending that kind of money, it is going to be sick, os here is sick. 7.1 dolby surround and 1080P HDMI, 135W per channel, and right now if you go to FRYS.com, it is normally $500.00 bt for right now it is only $449.00. But if you put this in, be prepared to buy a PS/3 as your next investment (Th best way to get Blu-RaY at an affordable price, plus many other features) and an upconvert DVD layer, which is only about $100.00 or less today. Then you better get ready to hear from your neighbors and the cops, because they are going to think a war has broken out in your place. Enjoy, I play movies that the sound is just so realistic, I hate to leave the house anymore. Also, remember, speaker placement is key, so know the optimal environment for your system and if you need one, I may be able to hook you up with a system room tuning DVD for next to nothing. This will allow you to setup your system and place your speakers optimally for your environment. good Luck.
Onkyo TX-SR606B
7.1 A/V Receiver with HDMI Up-Scalling
Onkyo USA:
FRYS.com #: 5586420
The Progression of Affordable High-Def Home Theater Continues with Full HD Integration and Video Upscaling As part of the second generation of
Onkyo high-definition-capable receivers, the TX-SR606 is at the forefront of affordable home theater. The key is to have the most capable version of
HDMI. The TX-SR606 provides high-definition video and audio processing for four source components—another first for
Onkyo at this level. From
Blu-ray Disc players to gaming consoles and cable/satellite boxes, you have everything in the digital realm covered. Apart from 1080p video, the TX-SR606 can upscale all video signals to 1080i, regardless of the connection, for output via
HDMI. Onkyo's own
RIHD (Remote Interactive over HDMI) also gives you inter-
operability with the displays and playback components from other leading brands. And with an expanded version of Audyssey's room correction technology, the TX-SR606 maintains the fullness of surround sound audio quality at low volume levels. The TX-SR606 offers all-round excellence rarely seen at this level
Special Features
- HDMI v1.3a Repeater (4 inputs, 1080P compatible)
- HDMI Video Upconversion
- 1080i Upscaling powered by Faroudja DCDi Edge
- TrueHD, DTS-HD Decoding
Amplifier
- # Channels 7
- Power (8ohms 20-20kHz 0.08%) /Ch 90W
- Power (8ohms 1kHz 0.7%) /Ch 105W
- Continuous 6ohms Rated
- High Instantaneous Current Capability 36A
- Amplifier Frequency Response 5Hz-100kHz
- S/N Ratio (LINE IN) 106dB
- All Discrete Circuitry
- Absolute Ground Plate
- Optimum Gain Volume
- Non-Scaling Configuration
- Bi-amp Capability For Front
Processing
- DOLBY Decoder DD Plus, TrueHD
- DTS Decoder DTS-HD Master Audio
- Direct Mode
- Music Optimizer
- Audyssey Dynamic EQ
- 192K/24 Bit DACs
- DSP Type / QTY 32 BIT
- Adjustable Crossover 40/50/60/80/100/120/150/200Hz
- Independent Crossover
- AV Sync
- Accurate Speaker Distance Setting
- Multi-Band Speaker EQ 5 Band
Connectivity
- Audio In/Out 7 / 2
- Digital Audio IN (OPT/COAX) 2 / 2
- Composite In/Out 5 / 1
- S-Video In/Out 4 / 1
- Front-Panel A/V L / R / V
- Component Video / Bandwidth 2 in / 1 out / 50MHz
- HDMI In/Out 4 / 1
- HDMI Version V1.3a Repeater
- HDMI Bandwidth 1080p
- HDMI Deep Color Capable (36bit)
- Analog to HDMI Upconversion
- 480i to 480p Processing (DCDi Edge)
- 1080i Upscaling
- Multi-Channel Input 7.1
- Surround Pre-Outs SUB
- Powered Zone2
- Zone 2 Line Out
- iPod Ready (DS-A2x, DS-A2, DS-A1)
- SIRIUS Radio Ready
Integration Access
Miscellaneous
- Pre-Programmed Remote
- Glossy Black finished Remote
- Simple Remote to change input & mode
- Color-Coded Speaker Terminals
- Auto Speaker Calibration W/Mic. (Audyssey 2EQ)
- On Screen Display Out
- Permanent Memory Storage
- Solid Aluminum Front
- Warranty 2 YEARS
