Hi
When the
Dishwasher is not filling in, you'll need to check for the water inlet valve,
the filter screen and the float switch/assembly. Also check for the float
assembly inside the dishwasher. When water is filling your dishwasher, a float
rises along with it. As the float reaches a certain threshold level, it
shuts off the flow of water, thereby preventing a leak. Sometimes the float can
get stuck in the wrong position in your dishwasher, and it can prevent your
dishwasher from filling. Sometimes it can happen due to float valve and on
other occasions due to float switch. Inspect the water hose coming to the
dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and
check for the continuity on inlet valve. If you don't get any value on the
multimeter then you'll need to replace the water inlet valve assembly.
Hope this helps...
Please post back if you need more information.
Daniel
