What brand and model?
Check this links:
- www.casio-europe.com/euro/watch/technology/radiocontrolled/
- www.radiocontrolledclock.com/
And finally, check this links for additional information: How do radio-controlled clocks set themselves to the atomic clock in Colorado?
Hope helps.
I agree unless this is a digital watch that has a daylight savings feature then you need to do this on your own (manually) this is typically don't by pulling the watch dial out '1' click to allow the dials to free spin. if the dial is too small for you to grip to pull out then you will need to use a small flat head screw driver to pry the dial out to the free spinning 'time adjust' mode.
The watch may need to be changed manually. You can set the watch by twisting the knob on the right side to make the hands move. In most cases, watches do not change automatically because of daylight savings time. If you have any questions, I will be happy to answer them. Hope this helps!
May I get the make and model # to help you more
You suggested turning the right knob to advance the time one hour I cannot turn the knob it is
too small and slippery.even using small pliers.
The reason I'm not satisfied Is that you keep telling me to twist the right knob and I tell you I I can not. The watch is radio controlled. The signal needs to come from the Company that controlls the watch. I can not find that co.
