Sylvania G-Netbook Logo
Posted on May 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i restore the netbook back to origanal i cant acsess the internet
Norman Worley
Level 3:
Genius:
  • Master 1,273 Answers
  • Posted on May 19, 2011
Norman Worley
Master
Level 3:
Genius:
Answers
1273
Questions
0
Helped
325139
Points
3473
First try the following information below to get the WiFi working. If you fail at that then there is a TIP on flashing listed below.
It is looking for apassword (WiFi Network Key) You have to double click on the little computericon down in the right tool bar area, the one with the two side radiating arcs,and possibly has a small red X under it. The red X indicates that it is NOTconnected. When you double click on that icon a window called RT28701 opens up,then you click on Wireless Information tab, then you cursor down to the name ofyour WiFi and high light it and click the connect box. Then another windowopens up called Network Properties. Uncheck "The key is providedautomatically" box. This will allow you to type in your "NetworkKey", the password that protects your network from outsiders. This"KEY" was set up when you installed the router on your servercomputer. If this does not work at first, turn the machine over on it's backand using a toothpick, insert it into the little hole about an inch diagonallyfrom the right corner of the data plate, this will re-load a new copy ofeverything including the WiFi RT28701 driver. sometimes thisdriver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing AdditionalInformation When I try to signon with the red X showing, I get "The page cannot be displayed If I thendouble click on the icon down in the right corner I elucidated above, RT28701opens up to "Internet Protocol (TCP/IP) with all zeros in the IP addressfield, and Subnet Mask, with no entries in the default gateway. That is a clueto me that the automatic sign on has not found a viable network, or needssomething else. If I then click on Wireless Information tab, the list ofavailable networks, appear in the box. The machine keeps trying to associate myprevious entered name site with my preferred site and tells me the signal isgood, but it cannot link up. This is a signal to me that it has lost my NetworkKey or that the softwarehas failed or both. I then click on advance and delete my preferred network andhit OK, this will force the software to ask me for my network again, and noticethat the preferred is missing. I click on the name of my network again and thenhit connect., then the Wireless Network properties window opens up and I caninsert my Network Key again after I uncheck the "The key is providedautomatically" box. I enter the key and hit the OK button. I still do notget a connection, so I reboot the machine, and wait for about 30 seconds andthe machine synchs up because the little RED X under the icon has disappeared.Now the machine will hook to the internet as long as I want to, but sometimeswhen I turn the machine on it will not synch, so I go through the abovesequence again. The secret is once you have entered your key and ask for themachine to synch up you have to reboot. Why? I do not exactly know, but Isuspect that the WiFi driver looses it You may also wantto look at the TIP http://www.fixya.com/support/r7679654-sylvania_syneto7526_wirless_keyboard To make your knowledge complete
Need to reset the sylvania netbook
Make sure your computer is on and working, and also connected to the internet.. Remember you will lose all data when you do this, so back up first anything you need to keep.
There seem to be two lines of thought on this.
1. The reset button on the back is about 1in. diagonally from the right lower corner of the data plate. Insert a tooth pick/a straightened paper clip in the little hole and hold for about ten seconds with the power plugged in. This should reset it to the factory specs.
OR
2. To do a system restore on Sylvania Netbook, you need to make sure that it is connected to a router. After accessing the internet, press "F9" key to start the restore process where it will restart to confirm and then ask for the password.
My acer aspire one d257-1417 trys 2 setup service but cant sumthing happen 2 microsoftwindows how can i recover without a cd
I'm not sure what you are referring to ?
If you do a factory restore and its a hardware issue the problem will still remain
You can reset the Acer Aspire One to factory settings just using your keyboard. Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive.
I had to reinstall driver (synaptics) on my recently bought asus u36sd since i managed to delete the driver while removing bloatware with a software. I did get my scrollfunction back but two finger- and...
Hi Ali.
you could try this or go to the link at the bottom and have a read up of what else you could try.
Push the computer's F9 button until the Recovery System window appears. Choose the option for Windows Setup and select Recovery. You should see a message disclosing that you will lose all your files in the process as the Recovery puts the machine back to its original factory settings.
How to Restore an Asus Eee PC Netbook ' eBay
www.ebay.co.uk/gds/How-to-Restore-an-Asus-Eee-PC-Netbook-/.../g.html
asus eee pc 1000he netbook restore factory settings Google Search
Cant get internet acsess or sync
use DFU mode while plugged into itunes. Easiest way to do this is by turning it off unplugged. open itunes and then plug it in while holding the home button. then hit restore on itunes when it pops up saying "iphone in recovery mode"
I cant get on the internet with my sylvania 7" netbook,I lost my desktop Icons ,I still 2 Icons ,Computer and trash. John J Reno ...
recent updates and newly installed programs usually are the cause of this problem. Updates can install some programs on your system with you not knowing.
First, try to perform a system restore on your computer. System restore can help to back date your computer to the time when the browser was working. It will revert changes made on your computer.
Go to Start > All programs > Accessories > System tools > System restore. Read and follow instructions on the system restore page before proceeding.
Your computer will be restarted after the system restore is completed. Thereafter, you can try to open your browser.
Secondly, internet virus can cause this problem. But try the system restore first, and let me have the outcome. So that If the above doesn't solve the problem, I could direct you further on what to do.
Good luck.
Want to restore to origanal system. where can i buy a restore disk?
The manufacture of the computer would be the best option. You would need to get the drivers to run the audio, internet, cd burner etc, so I always let people know to call the computer manufacture so you can get both cd's on one phone call. Hope this helps
2answers
Cant acsess internet exploreror get on web /dell dim 2400 celaron 2.60/2.59./512mb
your internet explorer will be in c:/programfiles browse for it and user
I forgot the 4 digit passcode for my iPod touch How Do I Fix ?
Go to itunes (with your ipod connected), go to the summary of your ipod (by clicking the name of your ipod under devices), and click restore. Then you can sync everything back on later.
Top Sylvania Computers & Internet Experts
Paul Bade
ADMIN Eric
ADMIN Eric
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
