SOURCE: mi Gemini TT 03 dejo
¡Hola
Su velocidad de motor de control de circuitos electr?nicos dentro se ha da?ado. Hay un control de velocidad de circuito regulador dentro de contro motor a diferentes velocidades. Hay transistores que se regula el voltaje que se suministra al motor. Cualquier transistor se da?a este tipo de falla ocurrir?. Apenas consiga que le den mantenimiento por cualquier technican servicio con experiencia. Si usted es el sonido en el servicio equipemt electr?nico que usted puede hacer por ti yoursef. El fallo se encuentra en su regualtor velocidad de circuito impreso hallen a bordo. Aceptar
Dear Sir,I have new motor+pcb for sale.I am from india.I can ship worldwide. [email protected]
SOURCE: Nesecito un c?digo para mi DVD Philips para q lo pueda encender con un control de dish
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
