Hummer H2 front tires rub when making sharp turns
If it definitely wasn't doing it before you took it in to the dealer and it was after they worked on it, then it must be related to what they have done and should be repaired by them. I recommend that you take it back again, ask to speak to the service manager and explain that you want it sorted out. If you get no joy from him, make an appointment to see the Dealer Principal (or overall manager, whatever his title is). I find it hard to believe that any reputable dealer would tell you that there is nothing wrong/nothing they can do when it MUST be something they have done in the first place. While the rubbing is probably not going to cause that much damage to the tyres, it is not exactly desirable either! If you still can't get any help from them, you could get another mechanic to look at it give you a second opinion. If they need to charge you for doing so, then you should be able to get reimbursed by the dealer once it is proven that there is an issue.
Sorry I can't help more.
