Problem with the feeder sensor >>top at the arrow
Close The door in the Top of the COPY Set
The cover on the document feeder may be partially open. Press the top of it while the document feeder is in the closed position. If you hear a click, then the top wasn't closed properly and you should be all set.
SOURCE: The copier keeps saying to put doc. feeder down and i it is. I ha
When you lift/ open the ADF you should see a tab in the back corner (slightly in from the corner) of the ADF. This tab is for the machine to see that the ADF is closed. Make sure tab is there. On its sister model they used a depression switch, check that and make sure it is there and working properly.
power supply has the fuse open that feed the voltage for the ardf
SOURCE: I'm getting a
On the rear left side of the copier there should be a black hinged actuator sticking up out of a hole in the panel, directly opposite of that there should be a white plastic tab that pushes that actuator down. If not try taping the actuator down flat with the cover.
