Question about Polaroid TLA-01911C TV
Need a manual for Polaroid TLA-01911C - Polaroid TLA-01911C TV
  • 55 Answers
Http://www.hdtvreview.com/Polaroid-TLA-01911C-hdtv.html
Posted on May 07, 2011
SOURCE:
  • 5 Answers
SOURCE: how to disassemble polaroid TLA-01911C lcd tv
1) Take the foot off the stand and with a long philips screwdriver remove the single screw that is at the top of the leg (inside leg). Then with the tv facing down lift straight up on the leg.
2) remove the two screws comming from the back of the tv along the bottom edge.
3) With the tv face down on a soft surface ( towel, bedspread, ect).
4) Be carefull with this step it this tv gave me some difficulty and I am experianced with this proceedure. Too much pressure or forcing it too hard will break your case. The back of the tv has a lip which inserts into the face.The face has tabs that lock into slots in the lip of the back. Carefully pry between the face and back pannel (I used my thumbnail and a 1" plastic putty knife.) and slide along the seam until the locking tabs pop loose. Continue sliding your instrument along the seam until all tabs are loose.
5) The back of the tv lifts off of the face leaving all electronics in the face of the tv.
That gets you into the tv. what you do from there is up to you, Good luck;)
Posted on Mar 19, 2009
  • 19 Answers
SOURCE: Polaroid TLA-01911C TV - I seem to have the same
I had the same problem - replaced the capacitors which cleaned up the signal. Then I hear a "buzzing" from the CCFL lamps. Turns out the solder job on the CCFL's themselves was shoddy and corroded. No good CCFL Power trips the inverter and turns the lamps off. Resoldering the wire to the end of the CCFL's fixed the problem permanently.
Posted on Dec 08, 2009
  • 19 Answers
SOURCE: Polaroid 19" TV TLA-01911C has no picture. Powers up, see logo
To add to this solution above - I had the capacitor replacement and there was still an issue. Turns out the solder connection to the lamps themselves was very very poor causing an electrical arc (the scratching noises people are hearing) - then the inverter shuts the lamps down as it should. Fix lights!
Posted on Dec 10, 2009
  • 12 Answers
SOURCE: PROB LEM WITH POLAROID TLA-01911C
It is related with Power
Posted on Sep 21, 2010
SOURCE: hi polaroid tla-01911c white screen
polaroid LCD has white screen and no sound
Posted on Jan 11, 2011
Fix sound on Polaroid TLA-01911C TV
Audio amp may be blown. A cable may be bad.
What are you connected to?
Apr 04, 2014 | Polaroid TLA-01911C TV
POLAROID TLA-01911C turns on but only white screen. no sound
Hello
The main board has the fault. Your set need a thorough check before confirmiing the fiault.
This is the picture of the board. OK.
Feb 16, 2012 | Polaroid TLA-01911C TV
Not really a problem but. I need to remove the base from a Polaroid TV model # tla - 01911c to get it into a box to ship
Good day!!!
all you need to do is to get Philip screw driver and remove all screw that connected to the base of your TV after that you can freely remove that base...
Thanks for using fixya...
Aug 11, 2011 | Polaroid TLA-01911C TV
THE CODE ON THE UNIVERSAI REMOTE DOES NOT WORK
There's more than one universal remote out there. Check a nearby Walmart, you'll shyt bricks at the sheer amount of universal remotes they offer.
Jul 18, 2010 | Polaroid TLA-01911C TV
The white screen and nothing else usually indicates a failure of the filter capacitors in the power supply board. When these capacitors go out the voltages are not correct so the TV can not power up right. You can rebuild the power board by replacing the bad capacitors and this should bring the TV back to life. Here is a link to a repair guide for this power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps,
BuddyMc
Dec 28, 2009 | Polaroid TLA-01911C TV
I have a Polaroid TLA-01911C. I switched from cable to air and did a scan, but no channels are found. I even hooked up an antenna with no channels found. Any suggestions?
Ether the antenna is not good enough for the digital signals that are now brodacasted or you got a bad digtal tuner in this unit. i would buy a antenna from radioshack special for this TV.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 18, 2009 | Polaroid TLA-01911C TV
Removing the stand from tv
I called Panasonic customer service and they directed me to their website where I was able to download that portion of the manual that addressed removing the stand.
Feb 03, 2009 | Polaroid TLA-01911C TV
Will Not Find A Signal Polaroid HD 15" TV - Model TLA-01511C
same (tla-01911c) issue when trying to watch over the air brodcast try rescanning the channels that normally works for me
i got direct tv basic set on my S-video input so i only need over the air when the sat is down (i.e: storms, wind, snow, ...)
May 15, 2008 | Polaroid TLA-01911C TV
Polaroid TLA-01911C TV Logo
787 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
