In order for the pressure switch to work it has to get pressure.
The switch is located near the top of the right side panel and can be seen by removing the top cover. There is a small pressure hose that leads to the switch and should be checked for crackes or chafing. There are three round sponges on this hose to keep it from rubbing on the moving parts. I had to replace mine after just over a year so I used a heaver hose with the same inner diameter. I used a 3/16 fuel line from Princess Auto and two new 3/8 stainless hose clamps.
ABSOLUTELY AWESOME! I checked the hose and sure enough about half way down it was chafed and cracked from the drum banging against the horizontal stiffener on the sidewalk about half way down. I sometimes would hear a banging when the drum was out of balance... They should have had shock absorbers at the top of the drum. I will add some heavy closed cell foam... On the way to the auto parts store! Thanks!!!
Fantastic insight. I had checked for clogs at either end of the pressure hose but you led me to the worn spot under the sponges. Easy fix saved me a bunch of time and $.
Wow this was right on !
Replaced the hose & wow . My washer is as good as new ! Thanks for the help !
Hi You are right....the issue is either with the pressure switch
or the water inlet valve. You'll have to test the water inlet valve with a
voltmeter, if that is fine then the pressure switch should be replaced. Please
check this diagram....part#203 is water inlet valve and part#208 is pressure
switch. Hope this helps...please post back for further assistance. Daniel
Hello dko 1227 - If your washer will not stop filling up with water it could possibly have one of the following issues: a defective water inlet valve, air leak, holes or defective pressure switch. Does the water stop coming in? If no, then replace the water inlet valve. However if it does, then there are either holes or air leaks in the air bell or pressure switch hose, meaning tighten or replace the defective part or pressure switch will need replacing. Contact a professional to move forward accurately.
Hope this helps you...Jim...Please leave a comment...Thanks!
LEAKS ALL THE TIME
Is your GE washer leaking all the time, even when not in use? If so the problem is the fill hoses or the valve. Look behind the washer to see if water is coming from the hoses. If not, take the cover off to the control panel. Once off, you should see if the water valve and if there is leakage - it needs replacing (if it is leaking). This is the most popular water valve for GE top-loading washers made after 1995 and the part number is WH13X86 Order Here. . Note that some models have a water valve with more than two coils. In this case, you will need to order the valve by model number at AppliancePartsPros.com Buy Fill Hoses Here.
LEAKS DURING FILL CYCLE
Is your GE washer leaking during the fill cycle? If so the problem may be in the valve. Follow instructions above, only this time start the fill cycle before looking at the valve.
If your washer overflows with water during fill cycle your problem is the water level control or the water valve. If you must cut the water off from the house plumbing to stop the water then there is no need for testing, just replace the water valve. First, you need to turn on the washer. The washer should start to fill with water, now cut the washer off and on repeatedly (note to yourself whether the water turned off every time). If it does cut off every time you cut the washer off, then it's most likely in the water level control. If it keeps running after you cut the washer off then, the water valve is bad and needs replacing. (Note that the valve can stick intermittently so it still may be bad if it passed the test) Water valves can be purchased at AppliancePartsPros.com
If the water valve doesn't stick in the first test then you need to check the water level control. First, remove the front of washer (insert butter knife between the top and the front pushing on the clips) then look on the side of the tub and you should see a tube attached to a box. Remove the tube (make sure all the water is out of the tub) look in the tube to see if is stopped up. Often it will stop up near the end. If it is, you can clean it out with a toothpick. Once it's clean, reinstall it and your washer is fixed. If the tube is not stopped up reinstall the tube. Now set the water level control on the lowest setting and start filling the washer with water. If the water stops when the tub is approximately half full (this varies with every model) turn it up to the next level (you may have to reset it). Repeat until the tub is full. If at any the water level gets above the last row of holes in the tub, unplug the washer. If the water stops running when you unplug the washer, replace the water level control. If the water doesn't stop, turn the water off at the wall then replace water valve. Water level contorls and water valves can be purchased at AppliancePartsPros.com .
LEAKS DURING WASH
Is your GE washer leaking during wash? If so the problem is the tub seal (seals around the transmission where it goes through the tub), drain hoses (including the tub to pump hose) or the pump. First take the front off the washer (insert butter knife between the top and the front, pushing on the clips) then start the fill cycle. Now start watching until you see a leak. If the leak is coming from the tub seal, the transmission needs to be replaced (note that changing the transmission is expensive and takes special tools, so you may consider replacing the washer). If the leak is coming from the drain hose or the pump you need to replace it. If you don't see it leak at all, your soap may be the problem. To check this fill the washer with water and the amount of soap you normally would use. Then start the washer and watch the tube coming from the left back of the tub (the overflow pipe). If soapsuds come out of the overflow pipe then try cutting down on your soap or switch to another brand. This may fix your problem. These parts can be purchased at AppliancePartsPros.com
LEAKS DURING PUMP OUT
Is your GE washer leaking during pump out? If so the first thing you should look at is the drainpipe (to your house plumbing). Fill the washer with water, and then turn it to spin and start it. Now while it's pumping, look at your drainpipe if water backs out (it may not back unless you have soap in the tub), then the problem is in your plumbing. If it doesn't, follow the same steps as above in "leaks during wash." Only this time watch for leaks during pump out as well.
