Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Posted on Nov 16, 2017
Hello I have a Hotpoint WF340 washing machine. It has just tripped the power supply. There was smoke coming from under the lid. I have removed the lid to find a cylinder to where the power supply cable goes too has started to melt. It has a part number of 411612437 on it. Do you know if this part is expensive and easy to change?
Jack
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Nov 16, 2017
 Jack
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
0
Helped
3697
Points
46
Go to the parts website for Hotpoint for price or Google the part number and someone will post it for sale.
Try going to You-Tube for instruction video on replacing.
If it is still under warranty, call mfg or warranty company.
5 Related Answers
Anonymous
  • 38 Answers
  • Posted on Sep 08, 2007
SOURCE: Hotpoint WMA20 First Edition
your bearings have gone and inturn your drum has droped which has cut heater so it has gone 2 earth which is y your electric has triped the whole job should nt cost more than £120 that is what i charge any way 4 a new inner and outer drum supply and fit good luck
Anonymous
  • 1036 Answers
  • Posted on Nov 05, 2008
SOURCE: hotpoint aquarius wf340
First remove the filter (if you can do this easily) - place a roasting pan under it to catch the water.
If you cannot get to any filter, remove the rear pipe from the waste pipe, and check it is not obstructed.
If it looks good enough, try a hot wash with 1 cup of soda crystals. This should clear any accumulation of grease in the pipes.
If still no good, you may have to open up the machine to clear any internal filter before the pump, and check pump vanes are still intact.
Anonymous
  • 903 Answers
  • Posted on Nov 24, 2008
SOURCE: wash enhance & on/off flashing
The only time the lights kept flashing on my Hotpoint machine was when the outflow pipe going into the ubend was blocked,
Check for blockages, but make sure that you have a bucket or pan ready to collect the water flow.
I hope this helps
Anonymous
  • 15 Answers
  • Posted on Dec 18, 2008
SOURCE: Where are the filters in Hotpoint Aquarius WF340 washing machine
if you dont have one in the front under the lid your model comes with a slip on filter that goes on top of the aggitator you schouldnt run it without it because ge pumps have a tendacy to freeze up with the lint from your clothes especcially levis hope this helps
Anonymous
  • Posted on Apr 29, 2009
SOURCE: WF340 hotpoint aquarius WASHINING MACHINE
Hi, Remove the drive belt from the drum & motor then turn the drum be hand, Is it noisy? if it is then the drum bearings need replacing i have used this website before and they are very good.
http://www.candmdomesticappliances.co.uk/section.php/88/1/hotpoint-washing-machine-spare-parts
1helpful
My washing machine keeps tripping the electricity
there is a shot on the power supply board, that's why it trips. Have is checked.
I have a problem with my hotpoint wf340 1400 spin when i put it on it washes but wont come off the wash cycle and will continue washing unless i stop it manually i then have to select pump out and then a...
it is either a broken wire to your heating element or the element itself is open circuit. when the water does not heat the machine will not move onto next stage of wash.
1helpful
The washing machine has stopped working and no lights come on
Hello there
If your washer doesn't seem to work at all, check these:
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
6helpful
How do you take the top off a Hotpoint WF340?
Remove the 2 rear screws of the lid & give a sharp blow to the front of the lid towards the rear.. there are keyholed lugs holding it down in place... use you hand not a hammer...lol.. Thanks
2answers
Where can i get instructions on how to use my hot point aquarius wf340 washing machine
You can retrieve a complete owners manual if you go to the manufacturers site, under"support" you'll see downloads, type in your model # and it will come through as a type "pdf." file to keep on your computer forever.
4helpful
Wash enhance & on/off flashing
I hope this helps
Hotpoint aquarius wf340
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
