Casio F91W-1 Wrist Watch Logo
Posted on May 06, 2011
How do you turn the hourly alarm off on a Casio F-91W wristwatch?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
878
Points
Ho do i set my f-91w
1helpful
How can I make my Casio F-91W watch beep every hour?
Deron, Check the attached links,manual,instruction and guides, Good luck .
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Casio 91W User Guide Quick guide to set the time and use all the functions
How do you turn off hourly beep on casio 91w
Casio F91W Module No 593 Watch
Ae 91w
THE CAPACITOR OF MIGHT HAVE SHORTED.
PLEASE GO TO AUTHORISED SERVICE. NO PERSONAL REPAIR IS DONE.
Casio not working
You need to Shortcut the battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs to get the watch started
I have a casio f-91w, and i would like to know how to turn on the hourly chime.. please help.. thank you.. peter.
I've never used one of these watches, but after looking online, I think this is how it's done:
Try using the top-left button to cycle through the settings, and use the button on the right to change them. So I'd imagine that after pressing the top-left button enough times, the indicator for the hourly beep will start to blink. At that point, press the rightmost button.
The indicator on the face of the watch should light up to indicate that the hourly chime is enabled.
How do you set the alarm for the casio baby g wr-10 bar?
mcdevito75 here, Contact Casio for a new manual at, 800-706-2534 Optn. 2
26helpful
3answers
How can you make a "Casio f-91w" watch not beep when pressing the buttons?
Push the lower left button. The alarm time is showing.
Press the lower right button and it will cycle the hourly beep and alarm on/off.
Press the lower left button to exit when the setting are what you want.
7helpful
2answers
For Casio F-91W how do I replace battery? I see 4
Most of these resin-case F-series Casio sport watches use a fairly large lithium coin cell battery. Once the four screws holding the watch back are removed, you should be able to just pop off the stainless steel spring clip that holds the cell in place and pull it out, without having to remove any more screws. Be careful when replacing the clip, because it is asymmetrical and goes in only one way. Also be careful not to lose the tiny spring contact that connects the watch movement to the piezoelectric sound element glued to the watch back. If you lose the spring, the watch will still run, but the alarm won't sound anymore.
11helpful
WR30 Wristwatch
hello,if you have the little circle window on the left of your face,that will tell you if the alarm and chime are on.
to turn them off you must push and hold the lap/reset button and at the same time push the st./stop button:
1 time takes of the chime-hourly beep
2 times takes off the alarm tha you set
3x's puts the chime back and 4x's puts the alarm back on.
2answers
How to turn off the every hour alarm on my casio 593 watch
go to mode menu scroll it and find the alarm mode ,when you see in a display a bell it will alarm every hour but if take the bell display it will not alarm every hour..
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
