Smeg 23 in. SE64 Gas Cooktop Logo
Posted on May 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Are all the plates supposed to show an igntion spark when depressing a single switch?.(mine do) Is that perhaps a safety feature.I have a suk61mfa/mbl5 Smeg Gas Sove . Many thanks
Tony Wisinski
Level 3:
Master:
  • Master 385 Answers
  • Posted on May 06, 2011
Tony Wisinski
Master
Level 3:
Master:
Answers
385
Questions
0
Helped
71562
Points
1176
Yes, that is a safety feature and your cooktop is working properly.
1helpful
We have modern Miele induction hob not sure of model it has three single hot plate, one large double extra speed hot plate one double hot plate its in demonstration mod how can l cancel?
I am assuming the timer display is showing "dE" . If you have the manual page 50 (programming) shows how to cancel demo mode. It is program P 0, currently it is set to "0" (demo mode), you need to change it to "1" (demo mode off).
1helpful
GE JGP 945 continues to spark. Removed all igniters but continues to click. Bad Spark Module?
no,its a bad switch on one of the gas valves,they are piggybacked on the gas valve and are supposed to turn on and off as the valve is turned on and off,on has broken and is on all the time even with that valve in the off position,carefully remove each switch from the circuit till it no longer sparks with all the valves in the off position
Short in knob
Replace the spark switch module on the bad burner.
Viking 30" gas professional series cooktop sparking problem
And before that Most likely one of the ignition switches (they are under knobs) got shorted possibly due to spilled liquid or a cleaning stuff sprayed on. In that case it should stop sparking after a switch drys. Still no go replace the spark control unit.
Thanks
Kindly rate the answer
Kevin
24helpful
2answers
Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Jun 18, 2009 • Cooktops
13helpful
4answers
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Indesit PI 640
i find your problem is short of desame line that why it remained lighting,try to hang the connection to that light,try to find it one by one , the principle of the lighting here is like in the rice cooker when warm the light is yellow when cook it turn to red when you going to see it ,it is one connection only.there is a thermal plate ,when it sense extreme heat it will move that to switch off ,,then when it warm its switch on. maybe there is short to thermal plate or the thermal plate not working even extreme heat it will not shrink...try to find this plate .if my solution help you to understand the problem please rate me FIXYA...
thank you in advance Stevecarr.....
Jun 25, 2008 • Cooktops
23helpful
Bosch ceramic hob
hold down powerboot for 4 seconds to switch off child lock
Top Smeg Cooktops Experts
ADMIN Andrew
ADMIN Andrew
Marty Warge
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
