HP LaserJet 5L Printer Logo
Posted on Aug 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp psc2410xi Printer stopped printing anything you could read-I assumed it was out of ink. I installed new color and black cartridges and now it gives me an error message-Romove and check color cartridge! I've done this several times, the cartridge is fine-but the error message remains. Any suggestions?
Suprrb Tech Support
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Aug 12, 2008
Suprrb Tech Support
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
6632
Points
15
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Anonymous
    Level 3:
    • Master 446 Answers
    Anonymous
    Master
    Level 3:
    Answers
    446
    Questions
    0
    Helped
    183344
    Points
    1173
    Cancell all file that was queued then re-seat the cartridge and reset the printer again
    2answers
    HP DesignJet 800 only prints in black
    Very strange error. I wonder if it is a driver issue? There were Microsoft Updates pushed out last night. Contact HP Support direct.
    https://support.hp.com/ca-en/document/bpp03052
    Hp 4480 how do you unpause it
    The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
    http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
      2.Release the Power button.
      3.The 'Tap 41' diagnostic test print should print.
      Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
      http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
      For additional support please visit http://www.inkjet411.com
      -Thank you
    Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
    Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
    For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
    Cannot make the printer work after I changed the ink cartridges?
    You can validate the HP60 ink cartridge's electrical health by running the 'Tap 41' diagnostics test (this procedure is specific to the F2480 model). Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test: http://inkjet411.com/?page_id=440
    1. While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2. Release the Power button.
    3. The 'Tap 41' diagnostic test print should print.
    --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout. http://inkjet411.com/?page_id=434
    ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
    Large ink spill. Printer no longer recognized new black cartridge.
    You can perform the Tap 41 Cartridge Health Diagnostics Test: [applies to HP Deskjet 6800/6900/9800]
    http://inkjet411.com/?page_id=1741 (refer to 2nd video to understand how to read the printed pattern)
    1. With printer power on, press and hold the POWER button.
    2. Press the Cancel (X) button four (4) times.
    3. Press the RESUME button (Down Arrow) once.
    4. Release the POWER button.
    5. The Diagnostic Test Report should print.
    --- A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout: http://inkjet411.com/?page_id=1741
    ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink (special "ink back-up mode").
    1helpful
    The printer's black ink cartridge won't print without the Tri-color print cartridge
    Most of the HP printers are designed to allow printing onlywhen all cartridges are installed and
    have ink.
    Install a new tri-color ink cartridge and printing will continue as usual.
    My printer, which is HP, does the same thing as yours, until I replace the empty cartridge,
    printing stops.
    2answers
    I have HP Officejet 6310 All-in-One I replaced black ink cartridge No 98 just recently, and since then I have problems to print anything. When I try to print I get this message on printer?s...
    hello, some of the time the color ink cartridge can cause the problem, especially if its a refilled ink, but at same time, i do know some of the new inks right out of the box will fail. so try with a new color cartridge first.
    It prints fine using the new hp 15 black ink cartridge. But when I print with the new color 17 cartridge, it comes out with uneven 'cross lines' of color, like sliced sideways. The printer seems fine and...
    it prints fine using the new hp 15 black ink cartridge. But when I print with the new color 17 cartridge, it comes out with uneven 'cross lines' of color, like sliced sideways.
    1helpful
    Printer reads "Incorrect Print Cardtridge Installed"
    According to the HP website, the correct cartridge for the HP PSC950 is HP15 or HP78. Comes in black only or tri-color.
    2helpful
    2answers
    Ink cartridge light keeps blinking BEWARE SPAM NUMBER 1-800-532-4187
    you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
    k24674
    Grand Canyon Tech
    Grand Canyon Tech
