CONTACT FOR NIKON CAMERA SERVICE- MATAELECTRONICS, NO 86,1ST FLOOR, SP RD , BLORE 2. CONTACT MR VIJAY 9035871324. VERY RELIABLE SERVICE AT MATA ELECTRONICS.
MY DSLR CAMERA HAD THE SAME ISSUE AND I HAVE TAKEN IT TO MATA ELECTRONICS, SP ROAD, 1ST FLOOR, BANGALORE. THEY GAVE ME THE CAMERA REPAIRED IN 6 HOURS .AMAZING SERVICE:) CONTACT 08022130711MY DSLR CAMERA HAD THE SAME ISSUE AND I HAVE TAKEN IT TO MATA ELECTRONICS, SP ROAD, 1ST FLOOR, BANGALORE. THEY GAVE ME THE CAMERA REPAIRED IN 6 HOURS .AMAZING SERVICE:) CONTACT 08022130711
You can't post conmments that contain an email address.
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp140 turn off printer. - put your finger and hold on/off with reset/stop button together - turn on printer power switch - release on/off button but in the same time still hold stop/reset button and then press on/off button again and hold. - wait at the moment- relese stop/reset button 2X.( your will see alarm led blinking for 2X) - relese on/off button.wait until your printer digital screen shows number 0. - after printer panel screen shows number 0. - press reset button 4x - press on/off button 1x - wait until your hear printer roller is moving - after your hear roller moving, wait until your dont hear anything from your printer then turn off and turn on your printer again and your will see your printer backto normal.
E2-2 = No paper (ASF) E3-3 = Paper jam E4 = No ink E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly E8 = Waste ink absorber full, or platen waste ink absorber full E9 The connected digital camera / video camera does not support Camera Direct Printing E14 The Ink cartridges whose destination are wrong E15 Ink cartridge is not installed E16 - Ink remaining is unknown E16 -E19 Failed to scan head alignment sheet E22 Carriage error E23 Paper feed error E24 Purge unit error E25 ASF(cam) sensor error E26 Internal temperature rise error E27 Waste ink absorber full or platen waste ink absorber full E28 Ink cartridge temperature rise error - E29 EEPROM error E33 Paper feed position error E35 15 USB Host VBUD overcurrent error - USB E37 17 Abnormal motor driver error E40 20 Other hardware error E42 22 Scanner error
First way
- relese stop/reset button 2X.( your will see alarm led blingking for 2X)
wait until your hear printer roller is moving after your hear roller moving, wait until your dont hear anything from your printer :)
then turn off and turn on your printer again and your will see your printer back to normal.
Second Way
The manual (pg 112) simply, and unfortunately, states this message "Press shutter release button again. If error persists, consult with Nikon-authorized service representative".
Some questions that might help: have you had the camera in some extreme conditions, damp, sand, etc. Clean the shutter button really well. Maybe use a small air blower and clean in the shutter release creases.
In the end, if the error continues, it will need to be serviced.
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon. olly
I had the same problem. I sent my camera to the Nikon Service Center. They fixed it within three days. They actually replaced the whole aperture frame. FREE OF CHARGE AS LONG WITHIN THE WARRANTY PERIOD.
