Try to auto adjust with your monitor if possible or try a different resolution to see what works better
beyond that you may wanna try to rollback your display adapter's driver
Testimonial: "Thanks, it worked but thinks look a little distorted. "
Ok, first open your Control Panel.
Then go to Appearance and Personalization and click on Adjust Screen Resolution.
Under display, make sure monitor 1 is selected.
Then change the resolution to 1024 * 768.
That should work. If it doesnt try other screen resolutions until it fits your screen.
Try a different resolution until you get your right resolution. What windows says may not be right in some cases. If that does not help make sure your video card drivers are up to date and try again.
