Do you have insert it with a wrong direction? Commonly, when you put in a SD card with a right direction, press it until the card has got to the end then loose your finger, the card will in place..
Confirm the features of your SD Card with this Nikon information...
While "WA" (Write Accelerated) cards may be approved for use in this
camera, no speed improvements will be noted over non-WA cards.
Additionally, look inside the C.F. card slot. I would bet that you will see a couple
of bent pins, one on each end of the connector. If you do find bent
pins you can usually straighten them out with a very small screwdriver. Check that the card in the slot is positioned correctly.
Keep us updated.
