Question about Olympus WS-300M Digital Voice Recorder
I downloaded files from recorder, then deleted files on recorder. When I went to record a new recording, the screen had a lock icon and said "can't input" or something like that. So i deleted all folders off recorder. Now it's saying "Can't Make System file. connect to PC and delete unnecessary files." But everything is deleted... help? thanks, julia
5 Suggested Answers
SOURCE:
  • 17 Answers
SOURCE: Can't use my voice recorder anymore
try to connect the recorder to the PC and with the Olympus DSS Player Version 7 change the folders name to default
Posted on Apr 04, 2008
  • 479 Answers
SOURCE: folders not deleting.
format the recorder through the recorder menu. but they are system files that will not be deleted. they are used by the recorder.
Posted on Oct 06, 2008
  • 919 Answers
SOURCE: Need to recover deleted file from recorder
Unfortunately this recorder model is designed with flash memory and once the files are erased they are gone. There are some companies that do specialize in flash memory recovery (Olympus is not one of them). You can go to google and search for flash memory recovery specialists. However this is a very costly process as it involves sending the device to these companies for them to do the recovery process.
Posted on May 22, 2009
SOURCE: Sony ICD-UX70/UX80 digital recorder...memory full problem
I solved the problem by connecting my Sony IC Recorder to the USB port on my McBook Pro computer and then emptying the trash can on the Mac computer. Visually (flashing red indicator light) and audibly (the recorder's sound that indicates something being erased), it was clear that mp3 files were finally, really being erased on the Sony recorder even though the recorder's own screen display had previously shown only empty folders and no files. Dragging files to the trash can doesn't really erase them unless you also empty the trash. All dragging to the trash can does is somehow mark the files in a way that, unfortunately, makes them invisible to Sony's file detection system.
Chuck in Omaha
Posted on Dec 19, 2009
How can i recover deleated files
You can recover deleted files with asoftech data recovery software. get the software from link below
Audio Recovery Software
Please be noted that your voice recorder memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
You may check out this memory card recovery tutorial also
Oct 04, 2012 | Olympus VN7000 Voice Recorder
Device stopped recording, or doing anything else. The screen shows a little lock icon. It is fully powered up.
The lock icon means you have switched the "lock" on ...this prevents accidental erasure of files.... if you need the operators manual go to www.olympusamerica.com ...manuals are under "SUPPORT".
Sep 09, 2010 | Olympus DS-4000 Digital Voice Recorder
The Olympus DS-330 read only memory lock
You may need to format the recorder to clean the file system on the recorder. Follow the directions below to format: If you format the recorder, all function settings will return to their defaults*. All files** stored in the recorder will be deleted. If you have important files that you want to save, connect the recorder to a computer and transfer those files from the recorder to the computer before formatting the device. * Date and time settings won't be cleared, so you won't need to set them again. ** Locked files will also be deleted. 1 Press and hold the FOLDER/MENU button for 1 second or longer. The menu opens. 2 Press the up or down arrows button to choose "FORMAT". 3 Press the REC/SET button again. 4 Press the FF or REW to choose "START". 5 Press the REC/SET button. Formatting starts. "FORMAT DONE" displays when formatting ends.
Jun 11, 2009 | Olympus DS-330 Digital Voice Recorder
Digital voice recorder connection problem
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Jun 02, 2009 | Olympus VN-2100PC Digital Voice Recorder
Olympus ds-30 deleted file recovery
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your device to a PC, and have a try of Photo Recovery (also recover audio, voice memos, video files etc), a data recovery program which is good at recovering media files lost. If you are Mac OS X users, turn to Data Recovery for Mac.
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. Regards
Nov 26, 2008 | Olympus DS-30 Digital Voice Recorder
Olympus DM-20 erase lock is on, how to undo it?
The voice recorder is in read only status - you will need to format the device to remove the lock (read only). Go to menu - to submenu and then run the format option. make sure all files have been downloaded as once device is formatted all files will be permanently deleted
Oct 16, 2008 | Olympus DM-20 Digital Voice Recorder
DS-400 DIGITAL VOICE RECORDER
went on the "menu" option and formated the disk. I first downloaded the files I needed to my computer. Took off the "lock" option.
Jun 25, 2008 | Olympus DM-20 Digital Voice Recorder
Recorder says "PLEASE DOWNLOAD FILES," but there are no files to download
The DS-2 has a format option in the menu under submenu. After you choose start you will see a progress bar and it should return to full record time. Use on a MAC seems to cause the reduced record time more often than on a PC.
Dec 11, 2007 | Olympus DS-2 Digital Voice Recorder
Olympus WS-300M Digital Voice Recorder Logo
83 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
