This is not necessarily a problem. The computer will utilize the cpu when it needs to, meaning, you are not putting much of a burden on the cpu if it is only running at 1GHZ. When you start to do more task, run more programs etc, you will see the CPU utilization increase!
I hope this is informative.
Regards,
G33k
In system information it states the processor is 1.1 GHZ? There are a couple of ways you can check the true processor speed/voltages. You can restart the computer and as it is booting up press the option to enter the BIOS. On some systems the BIOS will show CPU speed. There is a program called CPU-Z that you can use to see what the speed is. It may be just a reporting issue in Windows.http://www.cpuid.com/softwares/cpu-z.htm... <--download link
ok i downloaded it and i ran it. it says that my processor is running at 1102.5Mhz and it is a AMD Athlon MMX 3DNOW sse
Interesting. If you open up Task Manager(Cntrl + Alt + Delete) and look under the performance tab does it show the CPU usage maxed out? I would recommend at this point to go ahead and install new drivers for your computer. I checked the Emachines website but they do not even list your computer as being under support. I read a posting from someone with a similar problem but they were unable to get help from emachines. One Alternative, is to see if a update from Microsoft provides any related computer drivers.
Use this linkhttp://windows.microsoft.com/en-US/windo...
i cheked it and it is not there, i searched and founded something interesting chek it out, it said that it is used to fix a half running pchttp://members.driverguide.com/driver/de...
Good job finding that :) I would recommend you give it a try and install it! Let me know if it works.
ok but it is in 2 versions and i dont know whitch to use
I do not see two download options. On the link you gave me, click the big green download icon in the top center, not the top left. It will prompt you for a security answer, then you can download an .exe file. You should run this .exe file.
yes but in the readme it says that you MUST use the right version, i think its the 512 kb because in the cpu-z says that the level 2 has 512 kb so i will use it
well thanks but i mean it was in the system information 2.2GHZ and now its only 1.1GHZ
