IRISCARD PRO 4 SCANS UP TO 600 Logo
Posted on May 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Want to uninstall Iris Card Pro 4 from computer
Marvin
Level 3:
Top Expert:
  • Iris Master 85,242 Answers
  • Posted on May 05, 2011
Marvin
Iris Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29055586
Points
266281
To completely remove this program please download and install this SAFE program. It is called "Revo uninstaller" it removes every bit of the program from the registory memory.
http://download.cnet.com/Revo-Uninstaller/3000-2096_4-10687648.html
Matthew deSilva
Level 3:
Master:
  • Master 375 Answers
Matthew deSilva
Master
Level 3:
Master:
Answers
375
Questions
0
Helped
64153
Points
1156
If there was software installed onto your computer for this device then it should show in Control panel->add/remove programs (xp) or control panel ->programs and features (vista/7)
Simply highlight the line which refers to the software you wish to remove then click uninstall.
Hope this was helpful.
1helpful
My pc crashes when I start a wireless connection using the computer wireless button. Network card is Intel Pro 2200BG wireless LAN. Have reinstalled the driver with no success.
try this...
1. download the updated driver
2. go to the device manager then uninstall the wireless driver
3. restart your computer then reinstall the driver
4. restart your computer for the last time and the driver will be installed properly
1helpful
My Matrox rtx100 graphic is not dected by the computer.I could not install the driver
Hi!
Try uninstalling first display adapter that is currently installed form your device manager...how?...
1. On My Computer, right click and select properties.
2. Select Hardware tab, and click Device Manager.
3. On the list of device manager, click View menu and select Devices by type
4. Double click Display Adapters, to display the list of connected graphics adapter.
5. Disable the graphics adapter listed, by right clicking of the file name and select uninstall.
6. Now close any program and shutdown your computer..
7 Connect your video card to the motherboard and turn on your computer. Your computer will run its Add New Hardware Device , just be ready with your driver files..
I hope that will make your video card work with your motherboard
Much appreciated if you rate this solution..thanks.
1helpful
No sound. running core2 duo e7500 + 4 gb of ram + windows xp pro x64. gigabyte has been no help .
Your audio card may have died or you updated the sound driver in which case you will have to uninstall the driver and reboot the computer.
1helpful
Can not get the scanner to open, at all, no communication to the scanner. I have readiris pro 12, with an old HP OfficeJer G series scanner RP
DID YOU INSTALL THE SCANNER TWAIN DRIVERS, YOU NEED TO INSTALL IT TO SUPPORT YOUR SCANNER IRIS READIRIS PRO 10, AND WITH THE PROGRAMS INSTALL ALSO PROVIDING A CD OR DVD INSTALLER... ALSO READ THE MANUAL TO KNOW THAT YOUR SCANNER IS COMPATIBLE FIRST WITH YOUR OS or OPERATING SYSTEM, IT REQUIRES ON IT. AFTER THIS INSTRUCTION YOU MAY RUN YOU SCANNER PROPERLY... GOOD LUCK!
Swap 9800 Pro for 9700 Pro
You must uninstall the current driver and reinstall the driver for the 9800 Pro first:
http://ati.amd.com/support/driver.html
Power supply recommended is 300watt for each, so that is not a factor. It would have to be a driver conflict.
Lcd panel stays black
a penlight shined into zoomed back lens - shows if iris is open ( ccd looks like a small xmas tree scene , deep in center ) : if iris is stuck closed , a thorough lens cleaning should restore camera video - if iris is open , the ccd may be or already has failed ;
Top Iris Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Iris Office Equipment and Supply Expert? Answer questions, earn points and help others
