Question about Mitsubishi WD-65734 65" HDTV
There are white spots on TV . Heard it can be the dmd chip. Can DMD Chips be ordered. Or can it be any other problem? Can it be repaired at home?
  • 760 Answers
There is a very easy way to decide if it is your Digital board or your light engine. When you turn off your TV and the logo come up, are the spots still there? If they are then your light engine is bad and needs to be replaced. If they go away, then your digital board needs to be replaced. And yes you can get that board from just about anywhere.
Posted on May 05, 2011
Hi i have a Mitsubishi DLP HDTV 65 in and have a problem of white dots all over the screen ...i already change the lamp but it did not help ,is there any solution to fix it...thanks
Posted on May 13, 2011
SOURCE:
Is there any possible way to repair a DMD chip with tiny white dots?
Anything is usually fixable. What you have to determine with Dell's assistance is if it is cost effective to do so.
Nov 26, 2015 | Dell 1209S DLP Projector
White spots
It may be the DMD chip. Do you get the spots on the display even when there is no source connected? Are the spots multiplying? If so, then it is the DMD chip. If it is under warranty, then ship it back. Also, if the projector is less than 5 years old, you could get the chip replaced for free. Some DMD chips have a 5 year warranty that are still good even after the projector's warranty.
Mar 24, 2014 | ViewSonic Office Equipment & Supplies
White spots on projector
firstly make a clean for your projector DMD chips or color weel, if it still ahs whie spots, It should be dead pixels, since for the DMD chips issue. you have to replace a new DMD chips. i have DMD chips fit for Optoma EP761, it will cost USD123 with shipping
Jan 11, 2013 | Optoma EP761 DLP Projector
White dots on Viewsonic projector
after making a cleaing, if you still found the white dots, i think it is problem with DMD chips. you have to buy a replacement,
if your machine is ViewSonic PJD6221, congratulations, this model machine is used 1076-6038B DMD chips, at present, it is the cheapest DMD chips.
Feb 29, 2012 | ViewSonic PJD6221 3D DLP Projector
My acer projector have a white dots whats the cause
It is because of the DMD chisp faulty, you have to buy a DMD chips replaced. fortunately, this model DMD chips is 8060-6038B, it is not expensive, and normal, for any fuIt is because of the DMD chisp faulty, you have to buy a DMD chips replaced.
for any further help, please contact merther help, please contact me
Nov 12, 2011 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
Full with white stuck pixel
make a cleaing, if it still is full white dots, it should be problem of DMD chips,
buy a 8060-6038B DMD chips and instal it. only cost USD184
Jan 24, 2011 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
My optoma is projecting white spots onto the screen. They seem to just appear. Some have began by 'sparkling' for a while and then they stay white perminantly.
if it is a DLP projector then the DMD on the engine is likely bad or the main board is bad. The white things are pixels.
May 10, 2010 | Office Equipment & Supplies
White spots on TV Screen
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.</span>
Apr 20, 2010 | Televison & Video
Mitsubishi dlp tv WD65733 has white spots, like stars on screen, what causes this
If you get White or black dots all over the screen (DMD symptom)
If you get a pixilated picture (DMD Board)
Mar 27, 2010 | Mitsubishi WD-65733 65" HDTV
Mitsubishi WD-65734 65" HDTV Logo
794 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
