Connect the player to another computer and observe if it's going to work perfectly on that computer.
Which ever the case may be, here is what you need to do on your computer;
Insert the player into your computer
Go to device manager. (Type 'Device Manager under 'Search' and press enter on your keyboard. You will find 'Search' when you click Start menu which is located on the left button of your computer screen.
Go to the name of the player, under Universal Serial Bus Controller (USB) .
Right click on the player and click 'Uninstall"
Allow the player uninstall from your computer.
If possible uninstall every other device under the "Universal serial bus controller (usb).
Once this is done, disconnect/remove the player from your computer.
Restart your computer.
Wait
a while for the computer to boot computer. Also whatever you have
uninstalled from the device manager, might install automatically. Which
ever the case maybe, make sure your computer has finished booting or
installing any device before you attempt to insert the player
into the usb port.
Now insert the player and wait for the
computer to install the player, then observe if it will open
this time around on your computer. If it does, format the player and re-load songs on it, but this time, pt the songs bit by bit.
By now it should open. But if it doesn't open, please let me know so that I may direct you further on what next to do.
I wish you good luck.
Regards.
Hello, good to hear from you again. I think the ones that didn't work is as a of factory error. I don't think there is anything that could be done to make them work as others worked straight away. Take them back to the store where they were purchased. Replace the ones that didn't work with another. Regards.
The device is NOT the same as picture shown it is a 1gb preloaded mp3 Jazz prototype KXMP05 with links to "press and play" I only ask as I bought 40 of these for workers and after loading them only several worked while the others have failed. Under usb controller the divice still does not register that it exists even as a usb stick? I have tried and failed the previous solution. Not sure why these players are not registering. thanks any help would be greatful
